Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Compact fluorescent backlight
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Hi all,
    I'm building a compact fluorescent backlight upgrade (not CCFLs!) for my 7" Super screen using bulbs like these:
    http://genet.gelighting.com/LightPro...ouble+Biax®_T4
    ...except with a color temperature of 5000K. They'll be arranged in horizontal rows behind the LCD. Heat will be managed through a combination of case design and forced air cooling.
    I've searched for a similar project on the forums in an attempt to determine the overall feasability/any potential drawbacks, but all other backlight upgrade threads seem to revolve around using either CCFLs or LCDs. Anyone know of an attempted compact fluorescent light upgrade?
    Pics to follow...
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    I tried it. I used 6 850lumen (13w) compact fluros. It got too hot, even with a 120mm fan blowing into the lightbox.
    Dec 2005
    Dallas, Texas
    1) Aside from the cooling issue, did it effectively light the screen?
    2) What exactly do you mean by "too hot". Did it damage your LCD?
    Thanks,
    Gregory
    Dec 2002
    Montreal, Quebec
    It was bright, I'd say about twice as bright as the normal backlight. By too hot I mean that the box was so hot i couldn't comfortably hold my hand on it.
    Oct 2004
    NY
    floresent lamps are way to inefficent, & will make a whole lot more heat than the same amount of light from ccfl's.. why not use ccfl's, there not very expensive really or hard to get.... the side benifit of being able to dim them will be another huge plus... I don't get why you'd rather use the wrong thing for the aplication when the right thing isn't any harder really?
    5000k is more of a bluish white isnt it?
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    I think the CCFL is a better way to go. They are much more available and manage temperature much better.
    Brown 2010
    Dec 2002
    Montreal, Quebec
    Go with CCFL, or LED's. Those're the best options.. and neither is very expensive.
    arent LEDS directional though? so wouldnt you get "spotting" unlike an even glow with a ccfl tube?
    Dec 2002
    Montreal, Quebec
    Short answer: No.
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  2. Backlight upgrade, using Extra CCFLs.
    By Fusion-One in forum LCD/Display
    Last Post: 03-28-2006, 08:42 PM
  3. Backlight using compact fluros and a ligtbox?
    Last Post: 02-21-2006, 09:00 AM
  4. Replies: 4
    Last Post: 01-03-2005, 02:36 PM
  5. Schematics/Components needed for backlight inverter
    By BootySlap in forum Power Supplies
    Last Post: 07-13-2001, 09:32 AM
