Results 1 to 10 of 16
Thread: Weird problem with 8" Lilliput, please help
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    For the last two days, I have been experiencing a odd problem with my lilliput. The touchscreen has not been working correctly. Roadrunner sometimes registers when i press a button, but most of the time it won't. When I pull up the start menu in windows, it will work 50% of the time. I tried running the calibration program, but I kept getting kicked back to the main "general" tab everytime I pressed or clicked on another tab. (either using keyboard or screen)
    I decided while leaving work tonight to just leave it alone, and just listen to my playlist, having no control over track control, but I do have control of the volume using my powermate. Here's the really strange part- About 5 minutes from home, my screen suddenly went black with a "no vga input detected" box on the screen, then went completely black, with the music still playing. The screen went completely out. ( I do have the auto power on/off mod done to the screen) I thought maybe my power "egg" went out, or maybe my screen connector wiggled out or something. Then when i pulled into my driveway with the music playing, I turned the car off- the screen came back on greeting me with the windows logo with the "Hibernating" scroll bar beneath it. The the screen turned off like normal. WTF? Is it the VGA output from the board, or the screen?
    Any and all comments appreciated. -Thanks
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Sep 2003
    Tampa, Florida
    Oddly enough the screen worked this morning on my way to work. The touchscreen is still not working though. Maybe i'll re-install the drivers...
    WORKLOG
    Webpage
    Sep 2003
    Tampa, Florida
    I figured out why the screen went out. Somehow the power options changed themselves to turn the screen off after 20 minutes. I fixed that problem. I re-installed the TS drivers with the latest ones off egalax.com. However, I still can't get the TS driver to do a calibration. When I run the calibration utility, It askc me to touch the blinking "X". one second after I start touching the x, the screen goes away, and I am presented with the main touchkit display again. I don't know what the hell is going on with this. Does anyone have any input about this?
    WORKLOG
    Webpage
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    No idea, I've only run my TS under linux, but could it be it's mapping it to another button?
    Like, maybe you hit Right Click to get out of calibration?, it thinks your press is a right click. So you go to touch the X and it thinks your canceling?
    Sep 2003
    Tampa, Florida
    Maybe it is, But re-installing the drivers should of fixed it if that was the problem.
    WORKLOG
    Webpage
    Low Bitrate NoTicketsPlease's Avatar
    Jan 2006
    San Diego, CA
    i just upgraded my mobo/cpu and im having trouble with my lilli touchscreen. ill let you know of any info i find out
    Windows XP is ****!!!
    AMD Sempron 3000+, ASRockVM800, 256MB, 250GB 3.5", DVDRW+, WIFIg, m2-atx, Lilliput 8", RR, GoogleEarth
    Need: daylight viewable screen!
    Apr 2005
    Boston, MA
    Quote Originally Posted by Snootch
    Not saying it is, just something easy to try.
    Reinstalling the driver might fix it, or it maybe a mouse setting in MS itself and not something associated with the driver. I've had MS do inexplicably things seemingly without cause.
    Sep 2003
    Tampa, Florida
    The only thing the car was doing was sitting in my driveway with the ATX plug from the powersupply unplugged for a week. now when I come back home, I plug it back in, and all this stuff changes, (like the monitor power off setting) for no reason. I don't know what the hell the problem is. But i'm just about to give up and re-install windows.
    WORKLOG
    Webpage
    Apr 2005
    Boston, MA
    My lilliput does some odd **** too. The settings (brightness,contrast,rbg,etc) on some random startup will be all "0" for no reason what so ever. And this is in the house, not in the car with noisy power.
    Have you tried the reset option in the menu??
    Sep 2003
    Tampa, Florida
    Do you think that resetting the screen through the OSD would do anything to the touchscreen? I guess that will be my last ditch effort before I have to re-install xp.
    WORKLOG
    Webpage
  1. Lilliput Touchscreen Driver Problem.
    By gleinz in forum LCD/Display
    Last Post: 01-12-2007, 12:30 AM
  2. Replies: 2
    Last Post: 07-22-2005, 02:17 AM
  3. Weird Weird Weird Holux 210 problem
    By omernesh in forum GPS
    Last Post: 07-01-2005, 09:55 PM
  4. Lilliput LCD touchscreen problem
    By smartroad in forum Road Runner
    Last Post: 06-14-2005, 03:15 PM
  5. Small Lilliput display problem
    By Da_Teach in forum LCD/Display
    Last Post: 03-01-2004, 07:23 PM
