Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: LCD flicker, help!!!!
  1. #11
    Dec 2006
    ok so we need to regulate the power, I was wondering if instead of connecting it to the psu, could i buy some sort of DC-DC converter or something, does anyone recommend a good one or what i should be looking for?
    The speakers do the same thing, when accessing the hard drive I can here buzzing sounds comming from the speakers, I am running a 250w AMP.
    The screen does have a filter/regulatr or EGG box thing on it.......?
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    there's no converting to go from DC-DC.
    Best bet it to connect it to your PSU if you have the avaliable power on it.
    Else, you can buy a point-of-load for the screen if your power supple will support them.
    As for your speakers, that's a ground issue that could be any number of things. For that, please see this thread: Induced noise/Ground loop trouble shooting guide.
    So are you saying then that the screen does have an egg on the power line?
    Jan Bennett
  3. #13
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by RedGTiVR6 View Post
    Technically, a pol power supply is a dc-dc converter. No need for a supporting power supply, only if you want it to switch on/off with it, and even that is easy with a relay or hooking it up to your ACC line instead of directly to 12v.
    If the regulator is already used, it most probably is a grounding issue, maybe where your carpc is badly grounded (and grounds over the vga cable's ground, over the screen, to the screen's ground) or your screen is (the other way around).
    Joachim
  4. #14
    Newbie MRVJ245's Avatar
    Dec 2006
    SYDNEY!
    yeh i had problems where it was grounding thru my brothers Audi TV Module...NOT GOOD!
    For Bootscreens click Here
  1. FAQ: Using a Laptop LCD as Your Car PC Screen
    By cproaudio in forum The FAQ Emporium
    Last Post: 06-09-2009, 12:03 PM
  2. HD44780 LCD problem in cf 1.5
    By AngryMan in forum Centrafuse
    Last Post: 05-09-2006, 12:22 PM
  3. LCD flicker problem
    By zeppelinboy in forum LCD/Display
    Last Post: 11-16-2005, 10:59 PM
  4. DIY Lcd has flicker....
    By Blop in forum LCD/Display
    Last Post: 02-18-2004, 09:30 AM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
