Results 1 to 10 of 14
Thread: LCD flicker, help!!!!
    VMS
    VMS is offline
    Low Bitrate VMS's Avatar
    Apr 2006
    My motorised Lilli flickers.
    I've tried everything on suggested on the forum but nothing works. I can't power if off the PSU because it uses too much power.
    Its because of the harddrive, i think when the drive is accessing, its sending ripples though the VGA cable up to the screen. Any electronic experts care to share some knowledge?
    VMS
    VMS is offline
    Apr 2006
    anyone??? would grounding the LCD to the power supply do the trick, i'll give it a go
    Dec 2006
    im having the exact same problem as you!! did you overcome this problem? anyone else have any ideas? and your right, when the computer is processing it puts flicker through the screen.
    _
    Mar 2004
    Little Elm, Texas
    I found that updating the drivers on a friends PC solved his problems.
    Just make sure that you have a very solid ground and adequate power going to the screen in the first place.
    Jan Bennett
    Newbie MRVJ245's Avatar
    Dec 2006
    SYDNEY!
    i had a similar problem when using my OPUS Dc-DC Supply, it would ripple the video signal and pop the audio, it turned out one of the SMD Capacitor was faulty
    Does it do it when powering the PC with a ATX PSU?
    For Bootscreens click Here
    Jul 2006
    Jacksonville, FL
    Quote Originally Posted by MRVJ245 View Post
    Mine does
    Dec 2006
    everything is grounded and connected correctly as far as i know. when the computer is idle the screen does not flicker, but as soon as i access data or run a program flickering occurs (hard drive access) it doesnt do it connected to normal power and i have also tryed a video card in it with no luck!
    Ive read through the forums that connecting the LCD to the computers psu (m2-atx) it solves the problem, but is there another way around this? its driving me crazy
    Dec 2006
    SYDNEY!
    your power cable to the monitor, does it have a black box on it with a regulator and filter capacitor?
    _
    Mar 2004
    Little Elm, Texas
    the reason that connecting the screen to the PSU solves this problem for some is that the PSU provides more regulated power. From what I remember, the Lilli's need that regulated power, while the Xenarcs don't necessarially.
    Jan Bennett
    Dec 2006
    SYDNEY!
    Thats Correct, thats why they have the Regulator/Filter Box on the DC Line in for the Car Adapter
  1. FAQ: Using a Laptop LCD as Your Car PC Screen
    By cproaudio in forum The FAQ Emporium
    Last Post: 06-09-2009, 12:03 PM
  2. HD44780 LCD problem in cf 1.5
    By AngryMan in forum Centrafuse
    Last Post: 05-09-2006, 12:22 PM
  3. LCD flicker problem
    By zeppelinboy in forum LCD/Display
    Last Post: 11-16-2005, 10:59 PM
  4. DIY Lcd has flicker....
    By Blop in forum LCD/Display
    Last Post: 02-18-2004, 09:30 AM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
