looks great there Arby...is that the DennisK kit u have??
i just got the first shipment from DennisK last week...waiting on the Touchscreen now....
200 nits isn't the greatest, but it IS readable in direct sunlight.
Nope... Sharp LQ10D367. 10.4", 18 bit.
k...maybe u could help me out here then Arby....im still waiting on my screen from DennisK so i am testing a Sharp 9.4" LQ94D021 which i bought from Leslie...im hooking it up to my digiview ACG1024 card...but nothing happenes when i turn on the cpu...im using a 10VAC plug (could this be the problem?)...And i connected all the hirose cables it came with....So i dont know why it wont turn on?!
are the pinouts the same?Originally posted by SPyder_Flex97
did you fix the hirsoe cable connections like in leslie's thread here
10vac???? what do you have ac running to????? the controller card takes 12v DC, on the power plug the pin is 12v and the barrel is ground. i dont know where this ac business is coming from, and if you are running ac into the controller card.... time for a new card??? unless you mean that you took the plug connection off of a wall transformer and wired just the barrel plug end to a dc source?Originally posted by SPyder_Flex97
also, do you have a backlight turned on??? without a backlight, you will see almost no picture (maybe a tiny bit of color). if you dont have a backlight, remove the cathode tube assembly and shine a flashlight through the lcd. it will give you enough light to at least verify that it is working...
more.... you have to set a jumper on the controller card to make it turn on if you dont have the OSD board to controll it. if you have the OSD, make sure you hook it up, supply power to the controller, and then press and hold the on/off button for ~3 sec. that will turn on the screen. without the OSD board, i think you have to set a jumper so that it knows to turn the controller board on... i dont know that setting but check the datasheet
other than that...i have no idea!!!
~Mike
edit...on a side note... arby i hope you dont mind me stealing your mounting idea.... that is one fantastic setup and i think it will be hard to come up with something that works, and looks, as good as that!!!
Single Member of the "1000 Post and No MP3 Car" Club
PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
2000 Cavalier Z24 [###-------] Only 30% Done ... Still
Hey Arby, do you have any 8.4" 18 bit screens or know where to find one? I have a 10.4" touchscreen and I want an 8.4"![]()
here is the plug...hope i didnt mess up the card....![]()
AC BAAAAAD!
I sure hope you didn't kill it.
anyway of testing it to see if i killed it???
ACCCKKKKK
A/C, yikes. i hope that your card is still ok.... that controller card is freekin expensive if you have to buy another one.... its only putting out 500mA so you ?might? be okay, but then again, i have no idea if there is any sort of "reversed polarity" protection on that controller board.
to test it you are going to have to hook it up and see if it works... i believe that is the only way to see if it works!!!
easiest way to run 12v dc power is to use a 12v lead from one of the molex connections on a computer power supply...unless you are going to be pulling a couple amps... then i would suggest a dc power supply... look one up on ebay.
~Mike
