Lilliput 619 USB/Driver Problems? Let's research this... (unknown device)
Ok, so add me to the group of people that can get the Touchscreen drivers on the Lilliput 619 working for about 2 minutes on the first install on a clean system - then nothing after that.
Here's the deal. I've been able to get the touchscreen USB drivers to recognize the device on three occasions. All three instance were on a fresh install of the latest drivers from egalax.com.tw - fresh meaning that this is the first time they were installed on the OS. I waited until the software was installed to plug in the USB connector. On first discovery, the drivers detected the device as USB Touchscreen Controller, USB bus discovered device as VID 0EEF, PID 0001 (vendor and product IDs, used to discover identity of USB device and apply the appropriate drivers). Great - this is what we expect.
Now, if you unplug the USB cable and replug it, the device all of a sudden becomes "Unknown Device". If you follow the normal steps, and click the Nexts and all that as if it were a normally discovered device, you should be able to go into device manager and find the device under "Universal Serial Bus controllers" as "Unknown Device" - double click it to get the properties and then the Details tab to see that the instance ID is now reported as VID: 0000 and PID: 0000 - these values cause windows to report Unknown Device, immediately...
This is the part that puzzles me. It is the hardware that reports these VID/PID values. How would it change from reporting the correct values on a "virgin" system and then fail (with 0000 0000) on all subsequent attempts? Could it be possible that some piece of software is somehow interfering with reporting the proper values for the USB device instance?
If we can figure out why this is happening, I think everyone's problems will be solved. I'm still working on investigation, but wanted to get this info out there - maybe it'll trigger some thoughts from others...
Here's a slice of my c:\windows\setupapi.log showing how the values changed:
Code:
[2006/08/10 10:47:24 1100.3 Driver Install]
#-019 Searching for hardware ID(s): usb\vid_0eef&pid_0001&rev_0100,usb\vid_0eef&pid_0001
#-018 Searching for compatible ID(s): usb\class_ff&subclass_ff&prot_ff,usb\class_ff&subclass_ff,usb\class_ff
#-198 Command line processed: C:\WINDOWS\system32\services.exe
#I022 Found "USB\VID_0EEF&PID_0001" in C:\WINDOWS\inf\oem11.inf; Device: "USB Touchscreen Controller(Universal)"; Driver: "USB Touchscreen Controller(Universal)"; Provider: "Touchkit"; Mfg: "Touchkit"; Section name: "usb_univ_Inst".
#I023 Actual install section: [usb_univ_Inst]. Rank: 0x00000001. Effective driver date: 03/22/2006.
#I393 Modified INF cache "C:\WINDOWS\inf\INFCACHE.1".
#-166 Device install function: DIF_SELECTBESTCOMPATDRV.
#I063 Selected driver installs from section [usb_univ_Inst] in "c:\windows\inf\oem11.inf".
#I320 Class GUID of device remains: {4D36E96F-E325-11CE-BFC1-08002BE10318}.
#I060 Set selected driver.
#I058 Selected best compatible driver.
#-166 Device install function: DIF_INSTALLDEVICEFILES.
#I124 Doing copy-only install of "USB\VID_0EEF&PID_0001\5&817B42&0&1".
#-166 Device install function: DIF_REGISTER_COINSTALLERS.
#I056 Coinstallers registered.
#-166 Device install function: DIF_INSTALLINTERFACES.
#-011 Installing section [usb_univ_Inst.Interfaces] from "c:\windows\inf\oem11.inf".
#I054 Interfaces installed.
#-166 Device install function: DIF_INSTALLDEVICE.
#I123 Doing full install of "USB\VID_0EEF&PID_0001\5&817B42&0&1".
#I163 Device not started: Device has problem: 0x0a: CM_PROB_FAILED_START.
#I121 Device install of "USB\VID_0EEF&PID_0001\5&817B42&0&1" finished successfully.
[2006/08/10 10:51:00 1100.3 Driver Install]
#-019 Searching for hardware ID(s): usb\unknown
#-018 Searching for compatible ID(s): usb\unknown
#I022 Found "USB\UNKNOWN" in C:\WINDOWS\inf\usb.inf; Device: "Unknown Device"; Driver: "Unknown Device"; Provider: "Microsoft"; Mfg: "(Standard USB Host Controller)"; Section name: "BADDEVICE.Dev".
#I023 Actual install section: [BADDEVICE.Dev.NT]. Rank: 0x00000000. Effective driver date: 07/01/2001.
#I063 Selected driver installs from section [BADDEVICE.Dev] in "c:\windows\inf\usb.inf".
#I320 Class GUID of device remains: {36FC9E60-C465-11CF-8056-444553540000}.
#I124 Doing copy-only install of "USB\VID_0000&PID_0000\5&316CB136&0&2".
#-011 Installing section [BADDEVICE.Dev.NT.Interfaces] from "c:\windows\inf\usb.inf".
#I123 Doing full install of "USB\VID_0000&PID_0000\5&316CB136&0&2".
#I121 Device install of "USB\VID_0000&PID_0000\5&316CB136&0&2" finished successfully.
[2006/08/10 10:52:36 380.819]
#-199 Executing "C:\WINDOWS\system32\libusbd-nt.exe" with command line: system32\libusbd-nt.exe
#-166 Device install function: DIF_PROPERTYCHANGE.
#I292 Changing device properties of "USB\VID_0000&PID_0000\5&817B42&0&1".
#I303 DICS_PROPCHANGE: Device has been restarted.
