Results 1 to 6 of 6
Thread: change lcd background color
    Mar 2006
    Is there a whay to change the lcd background color from standard blue to red, i have an idea i am working in and i needs to be red, or is there and 2.5 or 3 inch lcds that comes with a red back ground
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Doubtful. Never seen anything but blue or black.
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    I have a 2" diffuser from a small LCD screen.
    If you shine red LED light on in, it'd turn into a red-lit rectangle.
    $5 and it's yours.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by HIGHGRADE View Post
    What LCD?
    What does the backlight look like?
    What are you planning to use it for? Nightvision?
    ...more information would really help answer your question...
    Short answer is just replace or add high-brightness LEDs to your LCD lightguide.
    Mar 2006
    most lcds come with a blue background, is it possible to chage it to red. I want to put two of these small lcds in my break light and when you press the break the video signal would cut and you get a red background.
    Is this possible
    does anyone know where i can find a 2.5 or 3 inch screen with red background thanks.
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    Is this possible
    Are you refering to the blank screen you see that is blue when you power up a small lcd?
    As for using as a brake light, good luck with the local revenue generators. Once Officer Friendly sees that, you will be in for a DOT insperction, and a ticket or 2. How can you use a red lcd display as a brake light? there is no way you would have enough light output to even remotely qualify as a brake light during the day. Plus, you need to have a change in intensity, or else the effect would be light turning on your headlights. people behind you would not know you are on the brake.
    Although it sounds like it would look trick if it was set up right, but I think you are asking for trouble if you drove a vehicle in the manner you suggest.
    Just my 2 cents, not trying to **** in your corn flakes. Good luck
  1. FAQ: Transflective Technology
    By nameeri in forum LCD/Display
    Last Post: 06-06-2006, 11:26 PM
  2. Lcd grounding issue, can't get rid of flickering
    By diskey in forum LCD/Display
    Last Post: 05-23-2006, 04:16 PM
  3. semi-noob color change question...
    By Tim97rs in forum Centrafuse
    Last Post: 07-28-2005, 06:55 PM
  4. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  5. 12.1 Backlit 16.7M Color TFT Analog VGA LCD *FS*
    By citrus3000 in forum Classified Archive
    Last Post: 06-17-2002, 06:24 PM
