Results 21 to 30 of 35
Thread: ...delete
  1. #21
    Jan 2003
    mirrored tint as in Car/Auto window tint? Get a mirrored high light transmission film....
  2. #22
    Oct 2004
    NY
    that's what I was thinking... it would have to be aplied like tint too, meaning wetting down the rear of the lcd... I think as long as it's controlled & too much preasure isn't aplied, & then if dried properly it should work.
    I would try it, but I got so many other projects going on that I haven't had a chance to... it has to work, but to what extent I don't know.....
  3. #23
    Aug 2006
  4. #24
    Apr 2006
    I opened up a few laptop LCDs and I can tell you they use several of those mirror sheets in each. One I opened had 2 and another had 3. Some were dimmer than the others. Maybe that helps.
    I was also going to give ths a try, but put the mirror sheet right under my touchscreen. I will give it a try once my carputer is installed.
  5. #25
    Oct 2004
    NY
    Quote Originally Posted by meddotnet View Post
    So how did the LCD work out after you applied the one way tint behind it. How good is it readable in the sun? or indoors?
    I haven't tried it at all because all of the screens I've been working with lately are already transflective screens... I don't have any real need for this because all of the screens going in my car are transflective & I haven't had time to play with any of my older non-transflective screens... some day I'll dig a few out & try this though, I'm curious if it'll be a huge improvement or not..
    Quote Originally Posted by Brib3 View Post
    the layers your talking about are what's called the "optical stack". usually 2-4 sheets, that consist of difusers & contrast enhancers, some are polarized & look reflective, but most laptop acreens aren't transflective at all... there are only a few different specialty laptops that even have the option of a transflective screen, unless you happened to have one of those, chances are it wasn't a transflective screen that you took apart.....
  6. #26
    Aug 2006
  7. #27
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    i would most definatly, but i am off the budget, i will try later, my suggestion you can buy used CASIO pocket tv on ebay for under 20.00 shippeed, and try it on smaller screen
    Yev
    R. T. F. M
  8. #28
    Apr 2007
    So did anyone ever give this a try?
  9. #29
    Nov 2004
    UK
    Not tried it, but the film is cheap enough - might be worth a try as long as it would be reversable
    http://cgi.ebay.co.uk/REFLECTIVE-MIR...QQcmdZViewItem
  10. #30
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    interesting idea...
    Subscribed
  1. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 12:45 PM
  2. Replies: 0
    Last Post: 12-08-2005, 11:41 PM
  3. Difference between VGA and Non VGA Screens??
    By sould in forum LCD/Display
    Last Post: 11-25-2005, 11:09 PM
  4. Cheap LCD screens while they last
    By Fiddler in forum General Hardware Discussion
    Last Post: 03-29-2000, 05:53 PM
