Results 1 to 10 of 10
Thread: From Lilliput to RNS-E (AUDI A6 1999)
    Newbie Xplorer's Avatar
    Apr 2005
    Limassol Cyprus
    For a while now i have my system running using a Lilli.
    I wanted to give a factory look to my A6 Carputer. I had two options.
    1. Get a double din cage and integrate the Lilli in the dash, then relocate the head unit in the glove box.
    2. Get an Audi RNS-E sat nav.
    Option 2 is a clean process, so I gave it a go. I will have to find a new input device, since the touch kit will be out of the picture.
    The next step? Purchase the parts required.
    1. RNS-E Sat nav. Found one on E-Bay in very good condition.
    2. CAN BUS emulator (This is required for Audi A6 pre 2000 models). The best place to purchase it from http://www.kufatec.de/
    3. Double din cage and climate control face. The colour of the RNS-E is soul black. I bought them from http://www.partsdealer.de/ , used but in excellent condition.
    4. Antenna adapter and removal tools which are very easy to find.
    So after two months waiting for parts, the migration process begun.
    - CarPC: Lilliput 7" Touchscreen, VIA EPIA M10K, 512 MB's of RAM, 40 GB's HDD
    -AUDI RNS-E
    Apr 2005
    Limassol Cyprus
    Migration
    Start point:
    Remove the upper cover:
    Remove the frame around the head unit and AC:
    Insert the head unit removel tools:
    Pool off:
    -AUDI RNS-E
    Apr 2005
    Limassol Cyprus
    Migration
    Heat unit removed:
    AC removed:
    Ash tray removed:
    Shift stick cover removed:
    Carputer in glovebox, needs to be taken out:
    -AUDI RNS-E
    Apr 2005
    Limassol Cyprus
    Migration
    Carputer Removed:
    Panel below steering wheel removed:
    Center console removed. At last, the single din cage can be removed:
    The double din cage installed:
    The RNS-E and AC installed.
    -AUDI RNS-E
    Constant Bitrate gokee2's Avatar
    Feb 2006
    B.More, MD
    damn homie. how much did dat oem sat nav cost? i know it was definitely hella clean. yeah it sucks cos the 1998-2000 A6s have like single-1.5 din and the 01-04 got double. Im getting prolly a 1999. If im lucky maybe a 2001 4.2L. So now, can u post screens of ur oem screen displaying your carputer?
    Dec 2005
    Quote Originally Posted by gokee2 View Post
    If you can get the 2001, that one has CAN and the RNS-E is much easier to retrofit.
    Apr 2008
    Hey, i have an A6 1998 with 1 din and i am planing to do the same nice job like your's. Please tell me this: do i have to buy another klima or i can use mine?? thank's a lot
    Jul 2008
    Hello
    I do the same conversion as your but at the moment I struggling a little bit. I cannot put the gear cover plate back in the place.
    Do you know the way to put it back and How you do that?
    Do I need to trim or change this plate or outside center console unit?
    In the conversion I change
    1. from 1din to 2 din bracket
    2. Climate control unit
    3. Ashtray
    Do I need anything else in this conversion.
    Thank you
    Jul 2008
    Hi Xplorer
    I did the same conversion as your. However, I cannot put the gear cover plate back into place. Do you have any suggestion how can I put the plate?
    In the conversion i change
    1. 1din to 2din cage
    2 2din type climate control
    3. 2din type ashtray.
    there is just only a small clearance between ashtray and lower plate.
    Do I need anything else or any part I missing for this conversion?
    thank you
    Sep 2011
    audi a6 navi
    thanks very much for the post, I've followed the steps and installed my dvd navi now, it's just a similar nav as the original one http://www.cars-electronics.com/audi...een_p1309.html I will post some pictures later.
  1. 2002 Audi A6 Bose Integration
    By bobbydude78 in forum Car Audio
    Last Post: 11-05-2007, 10:07 PM
  2. Audi A6 1999 Carputer Install
    By Xplorer in forum Show off your project
    Last Post: 03-30-2006, 04:19 PM
  3. 2001 Audi A6
    By ices11 in forum Show off your project
    Last Post: 09-20-2005, 11:07 PM
  4. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  5. Audi A6 custom install carpc with fingerprint recognition
    By ejdeleon in forum Show off your project
    Last Post: 07-07-2004, 04:25 PM
