Results 1 to 10 of 12
Thread: Lilliput picture quality...
    Jun 2006
    So I just got a brand new lilliput and the picture quality sucks, it is really grainy with multiple grain color... I can still read text and stuff, but what is with this grain? Is this normal???
    Mar 2006
    Colorado, but Canadian!
    Check your ribbon cable. Also, are you using the VGA, or composite input? What model? You buy new or used?
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2006
    new, i checked all the cables, they seem to be fine
    edit: its the 2005 model, one on this site, and im using VGA, but that doesnt matter because even the on screen display text has grain :|
    Mar 2006
    resolution?
    I have an Ex-Audio which I think uses the same screen and all, and it looks fine. Might be faulty.
    By cables do you mean inside or outside the casing? It could be a loose ribbon cable inside. Been known to ship that way.
    Jun 2006
    maybe this is how the screen is? if you look closely you can see fine grains... or is your picture perfect like your computer monitor right now?
    Jun 2006
    ok so i looked more closely and what it looks like is as if there were a grainy FILM over the screen... but there isnt
    does anyone else notice this? or is it just me, how should I fix this????
    ps im powering this off of a wall adapter that came with the screen
    thanks!!!!!
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Its the Touch Screen overlay..
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Jun 2006
    Quote Originally Posted by WebDog View Post
    so i guess i cant take it off?
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by mike6789 View Post
    Nope. It shouldn't be that bad. You'll never notice it once its in the car unless you mount the screen a foot away from your face.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Registered User
    Your touch panel has some kind of antiglare layer/coating, the previous lilliput models did not have any antiglare treatment so they dont have that grain like effect, but this causes it to look like a mirror when the sun is out. If glare will not be an issue for you try contacting Armen from www.digitalww.com, he should be able to get you an older panel. I've owned screens with both panels and i recommend sticking with the one you have
  1. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  2. Hard audio quality problem: Noise / Ground loop?
    By Burat in forum General Hardware Discussion
    Last Post: 09-09-2004, 07:08 AM
  3. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  4. lilliput picture is not aligned
    By vipergda in forum LCD/Display
    Last Post: 08-08-2004, 11:00 AM
  5. LCD picture quality not good. Will shielding help?
    By pigseye in forum General Hardware Discussion
    Last Post: 12-27-2001, 10:51 AM
