Results 1 to 3 of 3
Thread: Via Mini ITX VGA Out Works on some monitors, not others
    Aug 2006
    Does anyone know why the VGA out of a Via Mini ITX board would work on some monitors and not others? I thought maybe it was the age of the monitor, but I tried it on an 8 year old monitor and it worked fine. I tried it on my HDTV vga input and it didn't work, also worked on one monitor at work, but not another.
    Any fix or reason for this?
    Thanks,
    Rob
    Apr 2006
    Greensboro, NC
    VIA VGA Output
    I have a M10000 VIA board that works fine with every monitor and LCD I have, which is several. You may want to hit F8 and boot the machine in Safe Mode with VGA support to see if your monitor cannot handle the refresh rate you are currently using. Try looking on the back of the monitor to see if there is a list of the refresh rates that the device can use. e.g. 50-60Hz
    Aug 2006
    Both monitors are 50/60 Hz on back and set to 60 Hz in Control Panel
    This Mini ITX is also the M10000 and I believe uses the S3 Unichrome video card. I looked at the back of the monitors as suggested and both say 50/60 Hz and both monitors are set to 60 Hz in the Advanced Monitor Settings in Control Panel.
    Any other suggestions?
  1. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 12:45 PM
  2. aopen not reading vga monitors ?
    By xcite in forum LCD/Display
    Last Post: 07-19-2006, 05:15 AM
  3. 15" monitors and vga splitter
    By jesse13579 in forum Classified Archive
    Last Post: 06-19-2006, 02:19 PM
  4. P4 Mini Itx Mobo with Agp Slot
    By CJ8501 in forum General Hardware Discussion
    Last Post: 03-18-2005, 01:34 PM
  5. VGA LCD Monitors Vs. Standard LCD Monitors
    By yrga in forum LCD/Display
    Last Post: 09-27-2003, 11:34 AM
