you can try. shouldnt be too hard to find one of them. it is part of the power circuit by the looks of it.
where are you based?
if usa then try digikey, mouser etc etc. (i'm not too good with US stores as I am in the UK)
Hi all,
Wondering if there is a chance to fix my lilliput 619. The onboard fuse blew so I replaced it with an external one.
See the pic attached, I've circuled in yellow the thingythats blown. Now I'm not bad with a soldering iron, Can I replace the blown thingy?If so where can I get this part? Thanks
From downunder AUS mate.. So not much options here I assume.
May have to source it fromt he US I guess.
rubbish, you must have loads of electronics stores down there.
also digikey ships international anyway. we use them at work.
do you have Farnell down in Aus?
Only common electronic stores down here that I know of are Jaycar, Dick Smiths etc. But I'll check.
If I got asking for the part# do I quote looking for a DS1244 120? What is the part called? Google leads me to believe its a Dallas Semiconductor? Sorry I'm a complete noob that has half an idea on how to solder.
Cheers
could be something like this: http://www.fairchildsemi.com/ds/KS/KSA1244.pdf
(found it through digikey)
if it is one of those jobbies then mouser may have one i think.
Thanks Scouse Monkey,
Also whos mouser?
mate im in brisbane, where are you? We have plenty of good electronics suppliers in AUS, you just have to know where to look.
if your stuck PM me and I will try and find a supplier for you.
Hi soundoff,
Down in Syd mate. I think I've found a place called wagner. Hoping they will have it
