Results 1 to 10 of 10
Thread: I only get 640 x 480...no 800 x 600
    Variable Bitrate polo6979's Avatar
    Aug 2006
    Atlanta, GA
    I have the new Lilliput touchscreen with transflective and I installed the newested drivers but I only get 640 x 480. Why is that?
    2003 E46 BMW
    Lilliput Transflective, GM965 mobo w/ Processor
    ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
    Everything is for sale.
    Low Bitrate crez79's Avatar
    Dec 2005
    WA
    Some more information would be very helpful.
    Motherboard
    Videocard/chipset
    operating system
    Did you check the FAQ's?
    Yeah google!
    Mar 2006
    Colorado, but Canadian!
    Make sure you install your video drivers too.
    Images will display, but it is probably suck at 640x480 16bit too. Easy check is to see if you are able to suspend the pc. those rely on the videodrivers too.
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2006
    Atlanta, GA
    I have the EPIA CN 13000
    The video i am using is the Integrated VIA Unichrome Pro AGP Graphics with MPEG-2 accelerator
    Chipset is VIA CN700 & VT8237R.
    Wiindows XP
    Thanks for any help... I have tried the FAQs
    2003 E46 BMW
    Mar 2006
    Yes, but did you actually install the driver? Not just the automatic driver from window.
    Aug 2006
    Atlanta, GA
    yea... i just tried installing the video (VGA) driver from the EPIA cd... is that the correct thing to do?
    Still the same.
    2003 E46 BMW
    Aug 2006
    Atlanta, GA
    actually after doing that install the video is now a jumpy and shackes
    2003 E46 BMW
    Aug 2006
    Atlanta, GA
    ALSO.... the mouse is not following my finger. I try the allignment and it will not even click on the X. The mouse actually move faster than my finger. If i move my finger one inch the mouse will move all the way across the screen.
    2003 E46 BMW
    Dec 2005
    WA
    You may try to download the drivers from the VIA website.
    You could also try to update the bios which can also be found on the via website.
    The VIA forums may be able to help too.
    Sorry I can't be more of direct help, but if I can help point the way...
    Yeah google!
    Aug 2006
    Atlanta, GA
    thanks for your help.... I am still looking into this.
    I was able to get the mouse to start in the center of the screen with my finger but when I move my finger to the outside it jumps out there to fast.
    I dont understand it.
    2003 E46 BMW
  1. BMv2 Mappoint 800 * 480 .Skin Files
    By IntellaWorks in forum RR Skins
    Last Post: 11-14-2005, 04:03 PM
  2. centrafuse in 640 x 480
    By remonvts in forum Centrafuse
    Last Post: 03-02-2005, 01:17 PM
  3. 800 x 600 Xenarc resolution help!
    By Google in forum LCD/Display
    Last Post: 12-03-2004, 12:43 PM
  4. For those who run 7" Lilli's @ 800 X 600.
    By tbird2340 in forum LCD/Display
    Last Post: 10-30-2004, 12:40 PM
  5. I need a 640 x 480 skin
    By SurfinCajun in forum MediaCar
    Last Post: 06-08-2004, 09:33 AM
