you need to locate a little utility called lcdprint.exe. I have seen it floating around a bit, never used it myself personally....
then u can do things like
c:\>lcdprint.exe "Hello you, reading the LCD"
you can't just pipe the output from a DOS ECHO,etc to a printer/serial port and expect some action. its a little more advanced than that.....![]()
LinkBack URL
About LinkBacks
