Results 1 to 10 of 12
Thread: Mounting LCD in a 05 Astra
    Newbie §tudz's Avatar
    Aug 2006
    UK
    Unhappy Mounting LCD in a 05 Astra
    Hi,
    I have been discussing my carputer in the newbie section, but I have had little response to this question, and seeing this is the LCD/Display forum, I thought I'd post it here.
    I have searched the forums and the only astras I've seen on here are OLD ones (pre 05) and their dash boards are completely different to mine.
    I've been trying to find a suitable place for the monitor to go, but I'm stumped.
    I dont was to rip the dash apart as the car is amazing looking, here is a pic of the interior (got it from a astra site, as in work and cant take a pic of the car)
    http://i106.photobucket.com/albums/m...a_interior.jpg
    This is exactly like my car, Astra SRI CDTi 1.7 (2005)
    The car already has an onboard computer, and I dont want to loose the functionality from that, so I'm not going to take the screen out for that.
    the stereo has all the computer's controls on too, so I dont want to remove that, and the board below that is all the air-con etc controls. You see my plight?
    I said in my previous posy I was going to put it on a 'flip-out' from the glove box, BUT I wont be able to see the monitor from the drivers seat, so changing tracks, while driving will be a problem :S
    Does anyone have any ideas? I also dont want the display on show constantly, ie on a prop, which I've seen in the forums, as it would get pinched. The car got 'keyed' and covered in gravey with the first week of having it. Stupid jealous neighbours....
    §tudz
    www.studzworld.com - Only the Best Will do!
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    tbh you are pretty screwed! i thinkt he best approach would be to move the smaller onboard computer display and put your screen in that space. the smaller screen would be easier to find a new home for (eg sunvisors or where your driver side vent is)
    Failing that get a new facia with the vents in and hack that by having a flip out screen behind the vents (remove and block the ducts) and then have the vents open so the screen is fully hidden when closed.
    Aug 2006
    UK
    yeah I thought I would be.
    I did have a great idea but all these mod cons got me again, was gonna put it in the sun visor, but NO! they had to go and put a mirrow and lights in there
    I have a few Other Ideas:
    Idea 1:
    A flip out screen, can you suggest any for me, I'm looking at spend about £150 on the screen. All the ones I've found are built into a dvd/cd player, I just want the screen
    Idea 2:
    have the flipout screen mounted in the passenger foot well, so it pokes up and is facing me (not a great idea)
    Its SO annoying as I've even have a place to put the USB hub, so it looks intergrated, its just the monitor that is killing me.
    The curve of the dash also stops from having a dash mounted monitor too.
    Wouldnt closing off the vents cause problems? as its says in the manual to have all the vents open when the aircon is on, would it be a problem to have the air vents still open and blowing through behind the monitor, as I may be able to get a new facia and do some mods to it. although I have 0 skills (at least 0 that I yet know about) for hacking the facia apart.
    as for moving the current one, thats gonna be just as hard, so doubt I'll do that.
    If you can direct me to some standalong flipout monitors then I should be able to come up with an idea or three.
    §tudz
    Mar 2004
    Bristol
    flip out monitors in the UK: linitx.
    as for the sun visor....lose the ghey mirror lights. what are you an actor?
    Aug 2006
    UK
    yeah I am actually...
    no I not, I was just thinking, as I've seen one that was mounted ontop, not inside it. This could be an option, I would need to be remove anything then either if I come to sell the car, as the carputer wouldn't be going with it
    Just need a decent model for hanging/mounting on there, suggestions
    /me poses in a mirror...
    oh!
    /me hides
    §tudz
    Apr 2005
    Dublin, Ireland
    Take Put the BRICK, i mean radio and Get a Facia Adaptor or Customise Something, that Radio is all 05 + Opels and someone is going to have to take it out sooner or later, You could fit an aftermarket HU which will still connect to the screen and steering wheel controls (with right adaptors of course) and use the 2nd DIN slot for your screen,
    P4 Celeron 2.2 - 512MB - OPUS 250 - Audigy SE - BU353 - HQCT - No Speakers though :-(
    Apr 2005
    Dublin, Ireland
    How about a mounting point for the screen, some else did it on the form, didn't damage his dash either, you could have it at a 45 degree to yourself while driving, in front of the Radio or near the vents,
    Aug 2006
    UK
    I could, but as I said I NEED to retain the functionality of the onboard computer. SO changing that is not viable.
    SO many obsticals... it would have been fine if it were a basic model
    Also I'm gonna install a switch to change the speaker between the radio/cd player and the carputer. This ill save on buying a 'radio' adapter for the carputer. Savings! Savings! Savings!
    §tudz
    Mar 2004
    Bristol
    but if you use a switch you will need an amp. if you are happy with the stick volume and speaker setup and not looking to imporve it then get an aux in adapter as then you can use the stock volume control.
    what aboout relocating the top lcd to the arm rest area between the 2 front seats?
    Mar 2004
    Bristol
    actually, looking again...see how much the facia is from VX or see if there as been any crashed yet in breakers etc etc.
    then fabricate (learn how) the motorized screen in just below the exisitng lcd and relocate the hazard button. Then spray the screen silver to match the dash so when closed you wont see it and then when the pc is in use it will cover the top lcd and if you switch to radio you just close the screen.
  1. Mounting the MTSVO-SC LCD head unit in a 2005 Corolla?
    By Tellarite in forum LCD/Display
    Last Post: 07-19-2005, 12:37 PM
  2. Mounting a lcd in a 98+ Camaro
    By jm8881 in forum Fabrication
    Last Post: 05-23-2004, 04:14 PM
  3. mounting lcd
    By valentas in forum LCD/Display
    Last Post: 04-24-2003, 12:57 AM
  4. Mounting LCD to Dash - Won't Stick!
    By DaBretty in forum General Hardware Discussion
    Last Post: 07-02-2000, 12:55 AM
