Results 1 to 10 of 18
Thread: Help! I killed my Lilliput :(
    Newbie kenpojoe's Avatar
    Jul 2006
    Southern Cal
    I took it apart, mounted it, put it back together, now I have no power.
    I only unhooked 3 items
    1. the wire that goes to the speaker
    2. The connecter that goes from the screen to the board
    3. the ribbon that controls the buttons
    Thats it!
    When I plug it in I get nothing. I dont have any test equpment. Ive heard mention of a voltmeter, but wouldnt know where to connect it to.
    Any suggestions are greatly appreciated.
    Thanks in advance
    Joe
    01 Solara
    Lilliput 7"
    Jetway 1.5 GHZ C7 mobo
    512 DDR2 533
    M2-ATX, Csetrnc/Morex 2699R
    MPnt GPS
    SD F End
    WiFi
    BlueTooth - not working though
    ALPINE MRP-F250 4/3/2 Channel AMP
    http://www.mp3car.com/vbulletin/show...733#post917733
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    do you even get the "no vga signal" message
    Jul 2006
    Southern Cal
    No. I dont get anything. I'm actually just watching to see if the leds light up. Its like its not getting any power at all. I've checked the connections. everything seems to be in order.
    01 Solara
    Lilliput 7"
    512 DDR2 533
    MPnt GPS
    SD F End
    WiFi
    Aug 2006
    IMHO, Double check the Button Ribbon cable.
    Be sure you have replugged any ground you could have unscrewed. (If any)
    Is there a led somewhere that will light up when you get power?
    You didnt short anything if you powered it dissambled? did you?
    Mar 2005
    Rockledge, FL
    yea the power led on the left should light up green when it's on, red when it's off, but the ribbon cable has to be plugged in right, you also might want to check the LCD 40pin ribbon (white flat ribbon), if you unplug that cable and get a white screen at least you'll know if you're getting power or not, but be careful with the ribbon i'ts really fragile
    Jul 2006
    Southern Cal
    The first time I plugged it in I didnt have the ribbon cable plugged in (for the buttons) Could this have caused a short? I hope not. Is there a way to test for this?
    Thanks for the help
    Joe
    01 Solara
    Lilliput 7"
    512 DDR2 533
    MPnt GPS
    SD F End
    WiFi
    Jul 2006
    Southern Cal
    man I did something. I dont know how though. It doesnt seem to be getting ANY power at all. No white screen no leds no nada
    01 Solara
    Lilliput 7"
    512 DDR2 533
    MPnt GPS
    SD F End
    WiFi
    Aug 2006
    No short if it didnt touch anything metallic while powered.
    Also, some LCD wont light up if the Controls are not connected and/or you wont know that its on because usually the LED is on the same board.
    Mar 2005
    Rockledge, FL
    the lcd should still work w/o the button board, but without it you wouldn't be able to turn it on, unless you have a 619 like mine and you can program it to auto turn, i've ran mine w/o buttons just fine, i doubt that is the problem
    Constant Bitrate anik321's Avatar
    Nov 2004
    yayy solara! put up some pictures already!!!
    ok this is not at all a constructive comment whatsoever. sorry.
    there are a few fuses on the lilli. search a lil and it'll tell you where exactly.
    if your CCFL does not even turn on(the white light behind the LCD screen) then its pretty much a power issue.
    99' V6 Solara SE.
    '05 CBR600RR
    Baltimore MD.
    Shuttle XPC| 512MB | 120GB 3.5" Seagate
    Opus 150W PS | Rikaline 6010 GPS
    7" Lilliput 619 | Centrafuse | IGuidance 3
  1. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 06:26 PM
  2. killed my Lilliput touch panel
    By jeeve76 in forum LCD/Display
    Last Post: 05-26-2005, 11:45 AM
  3. Hmm.. possibly killed my lilliput...
    By Magma in forum LCD/Display
    Last Post: 09-02-2004, 03:08 PM
  4. Replies: 5
    Last Post: 04-01-2004, 04:37 AM
  5. I think I've killed my Lilliput!! Please Help
    By Glyn in forum LCD/Display
    Last Post: 04-01-2004, 02:54 AM
