Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Has anyone gotten the 800x480 on the SP13000 yet?
    Jun 2006
    Washington DC
    Searching through the forms I've seen people claim that that've gotten 800x480 on the SP13000, and then in the same thread people say they are full of it. Back and forth, Back and forth. It's been a whiile, sooooooo...
    "Has anyone gotten 800x480 on the VIA SP13000 to work yet?" If so, how'd you go about doing it (powerstrip, new drivers, etc). If you flashed the MB, do you have an .iso of your boot CD that you can share? Making one in XP is a royal pain (I tried to make one with Nero 6 and I got the stupid "Insufficient Memory" error). I even tried making my Sandisk Cruzier mini 256MB pen drive into a bootable device (to no avail).
    Low Bitrate jollyeskimo's Avatar
    Apr 2005
    Toronto
    After a lot of pain trying to create bootdisks and such, I flashed mine in windows.
    I don't remember the flashing program, but it's the generic one for the bios brand.
    Jun 2006
    Washington DC
    Isn't it generally frowned upon to flash your BIOS in Windows?
    Apr 2005
    Toronto
    Probably.
    It's ultimately up to you whether to do it or not. I'm simply offering what I believe to be the easiest way to do it on the troublesome floppy-less SP13000.
    Maximum Bitrate DeltaFX's Avatar
    France
    I recently flashed my "old" abit kx7-333 bios from windows (win98se), and it worked perfectly. Just make sure you use the prog designed by the manufacturer of your motherboard, and that you do it after a clean cold boot (not after a resume from S3/S4)
    Now Galileo is real. Muhahahahaha :p
    Constant Bitrate stealinfool's Avatar
    Dec 2005
    Orlando
    I've owned countless computers, probably each a different brand, and I've always used the company's bios flash utility in windows with no issue whatsover. (save using advanced beta updates)
    Like said above, a fresh cold boot and nothing running in the background will give you an easy trouble free flash.
    Jun 2006
    Washington DC
    After Flashing were you able to obtain the 800x480 like they claim it does, or does it still only do 640x480 and 800x600?
    Apr 2005
    Toronto
    Quote Originally Posted by TokyoJoe View Post
    I've been using it for months after I flashed mine.
    May 2006
    In my opinion it's impossible to use this resolution with this motherboard. VIA's tech support even says this. Also no one has been able to explain step by step how it could be achieved.
    So until VIA releases a BIOS which is capable of doing this, it's a no-go. I requested this, but only getting absolute silence from VIA after the initial reply.
    May 2006
    Quote Originally Posted by jollyeskimo View Post
    If this is really true, please specify the used BIOS file (Mine is 1.07, latest on the VIA website) and the steps taken to get the resolution set.
  1. 800x480 on the SP13000 with Powerstrip
    By theminor in forum LCD/Display
    Last Post: 10-16-2006, 11:32 PM
  2. Replies: 13
    Last Post: 02-13-2006, 08:55 PM
  3. SP13000 800x480 16:9 Output
    By scooby8272 in forum General Hardware Discussion
    Last Post: 11-03-2005, 08:34 AM
  4. Help me get 800x480 from EPIA SP13000
    By civic5zigen in forum LCD/Display
    Last Post: 10-27-2005, 04:24 PM
  5. M10000 vs SP13000, 800x480
    Last Post: 10-26-2005, 03:20 AM
