I think I figured out my problem. When I first put the monitor in the truck, I was powering it from the cigarette lighter, which is always powered, and the touchscreen always worked. I started having problems after I wired it to a switched source (the
radio power wire). I had done some other things at the same time, so it never occurred to me that changing the way I had it powered was the cause of all my troubles. Some of the time the monitor was showing up as “unknown device”, other times it wouldn’t show up at all. Sometimes I could unplug, and replug the USB cable, and it would start working.
I have since wired the monitor to my
power supply (M2-ATX). I just used an old Molex fan connector to make an adapter. Since I did this, it has worked 100%, and I haven’t had to unplug the USB even once. What I think was happening is that when I turned the key off, the monitor would lose power, and 5 seconds later, when the computer would go into standby without the monitor connected, and upon resuming, would not see it until I would do the whole unplug/replug routine.
So, if you’re having touchscreen issues, tie your monitor into your power supply, and see if it helps.
Good luck!
Scott
