Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: New DWW-750FM
    Aug 2006
    Pakistan
    Angry New DWW-750FM
    http://www.digitalww.com/DWW-750FM.htm
    Wish it was a motorized one.
    AG
    Elsewhere
    You're angry because the new models of in-dash touchscreen are eschewing the complexity of the motor?
    How about the Wiki?
    Aug 2006
    Pakistan
    Is it too hard to make a good (may be not perfect) motorized monitor?
    AG
    Aug 2006
    Quote Originally Posted by aghazi View Post
    AG
    Nope, but it would be very expensive. A "perfect" motorized monitor would be adjustable left and right (eventually store it's position into memory for vertical and horizontal angle), this will increase the complexity of the monitor mechanism, this will involve then a high reduction of it's duration (or chance to get broken), to solve this problems you have then to use high quality materials and technology = high expensive monitor ...now what's the market of a hi-end monitor? Sure it is not for our "hobby". It would be a professional market, and if you look around you im sure you'll find one used on industrial enviroment (space shuttle? lol).... maybe you have to sell your car to buy one, but hey it is PERFECT!
    Aug 2006
    Pakistan
    Hmmm so you guys are recommending that I should get non-motorized in-dash. But isn't it a hassle to pull a non-motorized in-dash? Is there any video showing non-motorized manual operations?
    AG
    Constant Bitrate Cravex7's Avatar
    Jul 2005
    Salisbury, England
    Dude, have a search around for the lilliput in dash motorised monitors and the problems they had and you'll realise why non-motoried is the best solution right now. To summarise for you; most, if not all were sent back as the motors froze. Manual monitors work by (when closed) you pushing the screen in which releases the lock and then pulling it out... Not really a hassle...
    "This bloke said to me you haven't got a clue about the damage the soap bar can do to you,
    I tried to see things from his point of view but I couldn't fit my head up his arsehole too."
    Aug 2006
    AG
    It's sure not easy as turn your key... but the question is: how much times you've to open/close your monitor? I've my carpc in use 90% of the time, i close it only when i park the car in the night or when i'm away from it (eg: in a bar.. disco...), then it wouldn't been a "whole day" repeated action.
    Apr 2005
    I bought a motorized one for the 'aww' factor. I'm so ****ed I did. First time I tried to open it the screen got off track and jammed, took it a part fixed that. A day later the VGA ribbon cable got stressed from the opening and closing and broke a wire. (Why the hell would you use ribbon cables for something that needs to move anyway?!!) A week later I got the new cable, then broke the little connector for the panel side of the ribbon cable...I swear that thing is IMPOSSIBLE to get on. So I cut off an end of my old cable and stuck it on top of my new one and hot glued it in..(hey it worked..) But the part on how the screen wobbles back and forth about an inch when you press it annoyed me the most, I ended up pushing the tray back manually so the back of the screen can rest against the dash.
    If I had it to do over I would buy a manual screen it a heart beat.
    Aug 2006
    Pakistan
    I thought these motorized problem were only limited to the ebay units and those purchased from DWW or MP3Car are fine.
    Thank you guys for guiding me to the right direction.
    AG
    Jul 2005
    Salisbury, England
    Couldn't say for definate but they (lilliput) put out a hell of a lot of ***** monitors before any working ones - getting people to basically beta test for them, nice...
    There's just less to go wrong with a non motorised and what does a motorised one add apart from the "aww" factor????
  1. DWW motorized housing plus xenarc/gain
    By lostreception in forum LCD/Display
    Last Post: 04-06-2006, 01:37 PM
  2. FS: single DIN in-dash DWW TM-701L, non-motorized
    By Tim97rs in forum Classified Archive
    Last Post: 06-27-2005, 10:10 PM
  3. Replies: 1
    Last Post: 06-23-2005, 03:18 PM
  4. Anybody use this from DWW
    By heartpumper in forum LCD/Display
    Last Post: 02-27-2004, 10:08 AM
  5. Auto turn on for the DWW TM-710VGT?
    By -al- in forum LCD/Display
    Last Post: 12-02-2003, 04:50 PM
