Results 1 to 7 of 7
Thread: DWW-700M gears broken.
    Constant Bitrate Outsider787's Avatar
    May 2006
    I just recieved a DWW-700M unit, and it appears that some of the gears have a few teeth missing, hence hindering the proper operation of the unit.
    The motors attempt to move the gears but no movement happens since some gears are missing teeth. The motors turn for a few seconds, after which they stop, and all the buttons on the unit start flashing.
    Anyway, has anyone replaced any of those gears? What source did you use?
    In the mean time, is there a way to turn the unit on, so I can test the video inputs?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Outsider787 View Post
    Did you just get it from DigitalWW? If so, contact him for a replacement. If you didn't get it from him, call him anyway, he can probably help you out with some replacement parts or at least a source.
    Michael
    May 2006
    Got a hold or Armen... we'll see where that goes.
    Are there any user manuals for the DWW-700M, and/or technical details I could download?
    Constant Bitrate legacy05gt's Avatar
    May 2005
    Georgia
    Same thing happens with mine. Its not when the screen extends, but rather when it turns upwards, it will get to about 45 degrees and then struggle. Sometimes it makes it, sometimes it quits.
    Let use know what Armen does for you, I am very interested.
    Progress:99% not 100% because theres always something to do...
    Centrafuse on XP (lited)
    EN15000
    120GB 2.5" SATA HD
    1GB DDR2 Ram
    M2-ATX PS
    Slot-Load DVD
    BU-353 GPS w/Mappoint 2k6
    DWW-700M
    May 2006
    Armen came through. Gear 1 had a few teeth missing (where gear 1 and 2 interface), so I I'm getting one of each. I figure if gear 2 broke the teeth, it might have some damage on it as well.
    You probably have the same gears that have the problem.
    Anyway, send Arman at DigitalWW an email. He might have some more gears kicking around.
    May 2005
    Georgia
    I have emailed techsupport@digitalww.com hopefully i'll get a reply.
    EN15000
    120GB 2.5" SATA HD
    1GB DDR2 Ram
    M2-ATX PS
    Slot-Load DVD
    DWW-700M
    May 2005
    Georgia
    I have received the replacement gears from Armen. I will attempt to replace them tonight.
    I am a bit dissapointed though about the replacement gears, not that the gears are plastic(which sucks) but there are a few teeth that are mis-shaped. I will go through each tooth before i install and try to make them as evenly spaced as possible.
    I am optomistic though that this will solve every DWW-700M problem.
    Currently when the touchscreen folds down, its a free fall drop, gotta manually help it up as well.
    EN15000
    120GB 2.5" SATA HD
    1GB DDR2 Ram
    M2-ATX PS
    Slot-Load DVD
    DWW-700M
  1. DWW - 700M : not opening
    By John_Duh in forum LCD/Display
    Last Post: 05-30-2009, 11:04 PM
  2. Uh-oh, 700M Problems
    By grapaslingo in forum LCD/Display
    Last Post: 08-30-2006, 05:37 PM
  3. Replies: 2
    Last Post: 07-19-2005, 08:43 PM
  4. Lilliput Stop working - Fuse 1A broken HELP!
    By slimmegane in forum LCD/Display
    Last Post: 05-30-2005, 04:49 AM
  5. Replies: 6
    Last Post: 12-06-2004, 03:04 PM
