Page 1 of 7 1234567 LastLast
Results 1 to 10 of 65
Thread: Dww-750fm
    Constant Bitrate morris_the_cat's Avatar
    Aug 2006
    Vancouver
    Dww-750fm
    Just got the DWW-750FM today. On first glance it looks like a solid unit. Only thing is all the labels on the wires (speaker outs & video/audio ins) are in Chinese, so I will have to take it in to work to have a couple of co-workers translate it for me before i dare trying to hook it up incorrectly. Everything else is english though. If they can figure it out then I should have it running on my bench over the weekend. The led display for the radio (when unit is closed) looks decent - seems like it has some flashy power meters & such on either side of the readouts. The unit seems solid so far. The push to open mechanism seems good too. It will probably be a few weeks before I get a chance to test out the amp as I won't be putting it in my car until I put together my mini itx & voompc (arrived last week), and my new baby is taking up allot of my spare time for things such as this. I'll post pics on the weekend, hopefully with it powered up.
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    The wiring is labled in the manual that's for download on the product's webpage. There is one incorrect item in that though. The Orange wire and the Red wire are labled backwards. The Red wire is for switched power, and the Orange wire should be "light control cable."
    Aug 2006
    Vancouver
    Thank you for that tip techy101. I found that the labels noted that change (once translated) as well. We were trying to figure out where the "light control cable" should be connected to in the car, any idea? I have to go to my local chrysler dealership tomorrow & find out their wiring colour coding too...
    Minneapolis, MN
    My guess, although I'm not sure, would be that the Light Control Cable would be the Illumination line, but I can't confirm that.
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    Quote Originally Posted by techy101 View Post
    It is. you connect that wire to the headlight switch. When the lights are on, the radio lcd (not the big screen) will dim. Just like a stock radio does. If the display for the stereo is not too bright at night, leave it disconnected.
    Aug 2006
    Vancouver
    Ok guys, I managed to power the unit up & get a few pics. I used my pocketpc for now as the VGA input device, so the resolution is only 640x480 & no touch screen set up. The actual carputer I willl be using is still being put together - today I found out I need a 44-40 ide converter so I have to pick one up tomorrow. Anyway, back to the unit.
    The 3rd pic is my set up, with 12v coming from an old pc power supply, the DWW-750-fm, my PocketPC, & my voompc with mini-itx under construction. The 1st pic is the first power up. 2nd pic is with google news in the Opera web browser. 4th pic is the front panel display in radio mode - but no antenna hooked up, so no sound. 5th pic is the menu semi transparent over the vga output.
    I was pleasently surprised to see all the buttons lit up with blue led's, as well as the volume/power knob. The front panel display shows a few equalizer settings, power bars, signal strength etc. Seems like it will be flashy when I get it hooked into the car with an antenna & speakers.
    That's all for the pics for now, I probably won't power it up again until I get my voompc & mini-itx all assembled.
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Hi
    I have seen that you have a window mobile phone...and have seen that you have make a clone of your screen with it...
    I would like know wich software do you use for this...???
    I have a Qtek 9600 (or HTC TyTN) and would like do the same via Bluetooth or WIFI (no USB cable...would just wireless solution)
    Aug 2006
    Vancouver
    Sorry, that is a dell axim x50v, not a phone. Just a regular pocketpc, that happens to have a vga out cable. No special software, it is all built in. I don't think u can do that with your phone, as it probably doesn't have the hardware in it like the axim does.
    Aug 2006
    Vancouver
    Hey guys, the power and reset button have one lead each coming out of the unit. Should I twin each of those with a lead from the black ground wire, and then connect them to the M2 power jumpers (J9) and the motherboard reset jumpers respectively? They are quite thin wires, so I wouldn't use it for a power switch in line with the main power leads to the M2. I will probably add a heavy duty switch for that. Any thoughts would be greatly appreciated.
    Nov 2004
    FRANCE
    Quote Originally Posted by morris_the_cat View Post
    I think I have same hardware as you...
    It's a 400Mhz ARM on Windows Mobile 5....
  1. Head to head shoot out of DWW in dash screens.
    By belezeebub in forum LCD/Display
    Last Post: 09-15-2006, 04:00 PM
  2. DWW motorized housing plus xenarc/gain
    By lostreception in forum LCD/Display
    Last Post: 04-06-2006, 01:37 PM
  3. FS: single DIN in-dash DWW TM-701L, non-motorized
    By Tim97rs in forum Classified Archive
    Last Post: 06-27-2005, 10:10 PM
  4. Replies: 1
    Last Post: 06-23-2005, 03:18 PM
  5. Anybody use this from DWW
    By heartpumper in forum LCD/Display
    Last Post: 02-27-2004, 10:08 AM
