Results 1 to 6 of 6
Thread: 320x240 graphic LCD - interfacing
    Registered User MP3IAN by Ian Gregory's Avatar
    Jan 2002
    Wollongong, Australia
    I have a 320 x 240 graphic LCD that i would like to rig up! Can you tell me how i would go about wiring this to my serial port then?
    details as follows:
    Hi guys,
    I am interested in trying to get my 6" 320x240 graphic LCD display connected to my serial port.
    it has Sanyo LC794xx controllers. It is from Data International Model: 32240 WN2C2W-H 316-2450
    Pins:
    1-4: D0-D3 Display Data
    5: /DISPOFF H: on L: off
    6: FLM First line market
    7: M Frame reverse signal
    8: LP Data latch
    9: CP Data shift
    10: VCC power supply for logic circuit (+)
    11: VSS Ground
    12: VLCD Power for LCD (-)
    13: VADJ Operating voltage LCD driving
    14: FGND front panel ground
    I have a feeling i may need a controller? Any ideas?
    What software can i use to operaite this?
    Where can i get an appropriate backilght inverter for this?
    Thanks!
    Jul 2001
    The Netherlands
    Hi,
    I think you need a controller to control the lc794's, I'm not sure, but I think my lcd also has a couple of these "behind" the main controller t6963C, like in this PDF I found:http://www.skylab.it/winstar_pdf/WG240128B.pdf .
    You'll also need a rs232 <=> ttl-parrallel converter I think. check Maxim for this
    If at first you don't succeed.........
    destroy all evidence you tried
    for info on t6369c LCD or Presslab's powersupply check:
    http://www.namms.tk <=updated!!
    Jan 2002
    Any ideas where i can get this controller (how much?) and what is Maxim. Sorry but graphic LCD's are a new domain for me!
    Dec 2001
    Paignton, Devon, UK
    Maxim are a big integrated circuit manufacturer and can be found at http://www.maxim-ic.com
    As for a controller - i haven't got a clue - where did you get the graphic lcd from - sounds like a good idea.
    Mediabox Hardware Project
    Current Stage: A complete redesign, although not much happening right now!
    Mediabox Software Project
    Status: Writing Sync Software (still) and playing around with interface
    To do: Far too much!
    Jan 2002
    Graphic LCD is from data international. I would really like to get it going and i will keep the forum posted.
    Apr 2001
    Here, There, Everywhere
    maybe query them for a datasheet..... when I got my char LCDs I was able to get about 30 pages of datasheets that told me all the timings and programming data I needed.....
    im sure if they stock the parts that their suppliers can give them a few datasheets for the products.... I would start with them..
    Project - GAME OVER :(
