Do you have actually green and white wires? If yes.. where's the doubt? Use the monitor ones!![]()
Well I got my monitor today but the wiring hardness and the manual do not match I don't want to play guess the wires anyone got one hooked up that can give me a clue?
Manual says
Green = ground
Red Battery
Black= Acc
Black= Battery -
My Screen says
Red=Battery
Black=Acc
Green=Ground
White=Ground
Help? I want to test it out and install it tonight.
The Issue is/was the manual said to hook it up one way, the screen had a key saying to hook it up a different way and the wires themselves were labled a third way. I have figured it out and it works fine once I got the resoulation and refresh rate correct.
what refresh rate and resolution are u using ? Mine doesn't show anything when i switch to VGA input.
