Xenarc is generally considered to be the best bang for the buck touch screen... however it is expensive...
no matter what screen you get, you will have to fabricate a bezel to make it fit in the double din location... if you remove your current radio you will be able to see if a 8" screen can fit there... but most likely a 7" will be the easiest to make fit
good luck!
LinkBack URL
About LinkBacks
