Post up a link or some pictures for a better responce as some monitors are re-named/re-numbered by different sellers.
have any one use one of this before. Would appreciate if someone could advice
VMI70A in-dash 7" TFT-LCD touchscreen PC VGA monitor
*NEW* direct from the factory
Features
7" TFT LCD touchscreen display
Resolution: 800x480 (native)
Supported Resolutions: 640x480-1280x768
Video Input: VGA input (15 pin D-SUB analog RGB interface)
4-wire resistive Touchscreen (USB interface)
PAL/NTSC color system
Full-function infrared remote control
On Screen Display Menu Control
Automatic display angle adjustment
High-Brightness CCFL Backlight
2 AV/RCA video inputs, 1 audio Input
3 month warranty
Package Includes
Remote control
VGA cable
AV cable
Power cable
Stylus
CD with touchscreen drivers
Operation manual
"This bloke said to me you haven't got a clue about the damage the soap bar can do to you,
I tried to see things from his point of view but I couldn't fit my head up his arsehole too."
Link to store with vga,
http://www.short-circuit.com/details...rs/vmi70a.html
and the user manual
http://www.short-circuit.com/manuals/vmi70.pdf
Car PC Status {------- }0%
Car Died along with Autonode Monitor after returned to me. Worked for 3 Months then died again. The car engined died not long after!
Upgraded to 2003 Infiniti G35 Coupe
Exploring options of a double din unit style Car PC.
That looks exactly like my SP-716, same manual with poor english translations. I'm pretty happy with my monitor. Some people have reported the plastic gears breaking, but mine seems fine. You may want to search on SP-716 here, there may also be other numbers for that screen.
yeah it does seem to be the same as the SP-716; How was your install, good or bad?
Elifromthevi,
The install was as easy as installing a head unit, solder power connections, 4 screws to mount to a frame, hook up UBS, video, etc., then bolt the frame to the car. It was kind of tight to put it on top of my new head unit, but that was just the A/C stuff in my Pathfinder. You can see pics in my worklog (see sig below)
[QUOTE=hohenyi;935151]Hi, I'm about to purchase a 7" indash for my car pc, have any one use one of this before. Would appreciate if someone could advice me on this thing. Thank You.
Features
Hi people.
I am also about to invest in this above touch screen monitor. looks and sounds the part but how have you people found it?
whats the quality like? and would you say it is reliable?
your response will be appreciated
cheers all
No problems with mine...
seems I am the only one with problems on this screen.
bought it from ebay and the seller has dissapeared.
somebody knows yuki?????
Mine has built in TV, no FM. The reception pretty much sucks for TV and I didn't even hook up the antennea for it once I mounted in the car. BTW, it's a PAL antennea and you will need an adapter you can get at radio shack(I think it is part# 278-261). There is a thread on that somewhere...
I have constant power to the batt and acc to the acc line, both with inline fuses. Seems to do OK for me. Your milage may vary.
