Results 1 to 5 of 5
Thread: anyone seen these before and have an opinion?
    Constant Bitrate tdb30_'s Avatar
    Aug 2005
    Central MA
    I'm wondering if this is any good and if it automaticaly opens when the power is applied or if you always have to push the button. Oh, and if the backup camera video automaticaly switches to that input.
    http://cgi.ebay.com/In-Dash-Touchscr...QQcmdZViewItem
    Constant Bitrate Eternalodyssey's Avatar
    Oct 2005
    St. Louis, MO
    Not unless there is remote wire that you hook up to your 12V going to your back-up lamps. You would need a way for your vehicle to tell the monitor when to display the rear view camera. Otherwise you must use personal interface (hitting a button) to switch between the video input feeds.
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
    IS JACK BAUER GONNA HAVE TO SMACK A *****?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    that does look nice....amazaing how we have so many options these days. 3 years ago.......there werent any motorized vga touch monitors
    PC Components:
    My work log
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    looks virtually identical to a K301 which opens on ignition. Going by the label/wiring diagram it has input for the reverse switch so I would say it will switch to reverse cam automatically. Main difference I can see to the 301 is it doesn't have as many AV inputs.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Aug 2005
    Central MA
    The contrast ratio is 150:1 which is only half of the K301. Will this be an issue?
