Results 1 to 3 of 3
Thread: VM7000 / Lilliput 629GL-70NP Brightness Problem
    Zok
    Zok is offline
    Aug 2006
    Hey Guys,
    I have a VM7000 which supposably is a Lilliput 629GL-70NP in a different case... anyway when I made the dash bezel for it I had to remove part of the case and of course had to take all the guts out and when it all went back together I thought it had gotten a lot dimmer but I could tell from the side that the backlight was still running, so I kept going but now that its in the care, its completely unreadable (like you can hardly tell its running)... is it possible that I managed to turn the backlight way down in the process of taking it apart?
    The screen supposably produces 280 cd/m2 through the touchscreen... ive gone into the settings and monkeyed around with the brightness and contrast but they just change the way different colors are displayed, they dont change the actual brightness of the screen.
    Does anyone know of anything I can try?
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    For lilliput one you have to push the right arrow on the screen and you will go through 3 different brightnesses sequence.
    Zok
    Zok is offline
    Aug 2006
    Yeah, it has the options, but they only change the level curve on the color outputs, it doesn't change the brightness of the backlight at all.
  1. DWW-700H Brightness Contrast Problem
    By vdog in forum LCD/Display
    Last Post: 02-03-2006, 03:44 PM
  2. lilliput 629gl touchscreen problem.
    By Dave_Perth in forum LCD/Display
    Last Post: 01-31-2006, 12:28 AM
  3. lilliput brightness issue
    By fallnangel in forum LCD/Display
    Last Post: 06-11-2005, 08:22 PM
  4. Replies: 7
    Last Post: 04-18-2005, 12:41 PM
  5. Lilliput Touchscreen problem
    By DookieGraphics in forum LCD/Display
    Last Post: 03-24-2005, 02:33 AM
