Results 1 to 9 of 9
Thread: How to ideal wire +12V to LCD (Xenarc)?
    Constant Bitrate urosbe's Avatar
    Mar 2005
    Question How to ideal wire +12V to LCD (Xenarc)?
    I would like to know how you have wired the power cable to your LCD screen? In my case this is Xenarc 10" and Via Epia motherboard. For the past 1 year LCD got +12V from ignition... the same wire I use to connect to white connector on M1/M2-ATX (ignition). In that case every time that I remove the key, LCD went off, and I haven't seen what computer was doing (hibernating...). Now I decided to use standby instead of hibernation. And I wanted to wire +12V from somewhere from my motherboard or powersupply. 1 reason is that it would be more stable souce, 2. reason, I would like that LCD turns off when computer turns off. I tried to wire it to P4 connector from M1/M2-ATX, but unfortunatelly I realized when computer goes to standby, powersupply still has +12V on this P4 connector. I was searching and looking where on the motherboard is a +12V signal that goes off (to 0V) when standyby mode is on?
    Uros
    System: VIA EPIA EN15000,512 MB DDRII,M2-ATX,300GB HDD,XENARC 1020TSV,VoomPC case
    USB: Powermate,WinTV+FM,WLAN 54G,Bluetooth,Haicom GPS mouse SIRFIII
    Software: Windows TinyXP Rev06+MinLogon+EWF+HORM+Centrafuse 1.2
    Honda delSol project
    CarDomain
    Elsewhere
    HDD molex conenctor.
    Use the yellow wire for +12v. The red is +5v.
    How about the Wiki?
    Mar 2005
    I tried with this too.. but molex also has +12V and +5V when standby mode is active?! It is strange because HDD turns off, but I checked twice... HDD still has all values (12V, 5V on molex), is it possible that HDD "knows" that it has to turn off from IDE cable?
    Do you also know is it possible to turn of powering all USB tools when standby mode is active? And my CPU cooler on my Via Epia is also still on...
    CarDomain
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    The best thing I'd do is wire a Molex connector like DarquePervert said.
    For the reason of it being a clean 12V power (does not skip from 11 to 14).
    Then, on the yellow (+12V) wire, I'd put a relay and have it turn on and off based on the accessory wire (much like your amp/PSU turns on when you turn the key).
    It's a bit more complicated, but you can cut the 5V power to the USB devices in a similar manner.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Mar 2005
    Ok, but in this case, LCD will turn off when I remove the key. The only advantage of it is that in this case I have stable +12V from CarPC.
    About USB - is there any wire on ATX connector that can be cut (by relay) for USB power?
    CarDomain
    Apr 2005
    Here's an experimental method you could use:
    An USB optical mouse always has its light on when the computer is on.
    When the computer goes to standby, the LED turns off.
    If you could have a small relay feed off that ~5V (probably between 3 and 5 volts) to turn on/off your major accessories (like the LCD, amps, etc.), then it would work for you.
    Mar 2005
    Ok, I figured it out By default S1 was selected in BIOS and even if I've changed it to S3, standby mode behafe the same. It was because I didn't restarted Windows (hibernation was on). Now everything powers off, except ram and USB. Now I have to use this "relay" to power off USB when standby is active.
    It cannot be done on USB integrated on motherboard, but if I use 2 other USB connectors, I have all USB pins avaiable... I can use 2 USB hubs then on those 2 USB ports that is enough for 8 devices and everything will power off.
    But I would like to ask you if it is enough if I cut only USB+5V pin and connect it to relay? USB pins are: USB+5V, USB_P-, USB_P+ and GND. Only first pin matters?
    Uros
    CarDomain
    Mar 2005
    Nobody reads this?
    CarDomain
    Aug 2006
    using a relay
    you should be able to use a relay on any device that completely turns off in standby mode.
    use a multi-meter to test for power on the device chosen, before you start splicig or anything.
    to use a relay, you will need to have both a positive and negative for your switch (in the relay)
    see bottom of this post for an example
    I'm using the usb as an example of this because you mentioned it earlier.
    read the documentation coming with the relay to make sure that you hook it up correctly.
    also, any 12v source for your relay should work, assuming that (1)there is high enough rated fuse and wiring to power your monitor, and (2) it's always "hot", or getting power, even when your key is removed.
    cigarette lighters are usually good examples, however sometimes are switched with the ignition.
    if there is no docs that come with it, use a multi-meter to test for conductance, by using the ohm setting. when you get a reading similar to touching the two probes together, you're in business.
    that is, assuming you have a SPST relay. if you go to radio shack, they should be able to help you (although, recent personal experiences say the people working there don't know squat about electronic components)
    this is the url for a relay that SHOULD work no matter where you decide to tap into on your computer, either 12v or 5v.
    it also has a diagram painted on to the relay, helping to ensure proper connection.
    http://www.allelectronics.com/cgi-bi..._CONTROL_.html
    I hope that this is helpful.
  1. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 11:10 AM
  2. Replies: 6
    Last Post: 09-30-2006, 12:32 AM
  3. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  4. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 01:47 AM
  5. xenarc controller wire extension
    By G35Pimp in forum LCD/Display
    Last Post: 03-04-2004, 06:39 PM
