Results 1 to 4 of 4
Thread: How to reduce the display size ...
    Low Bitrate JPMG's Avatar
    Jan 2006
    I'm sure there has to be a slick trick, since I remember seeing a solution to this a while ago. Any help will be appreciated .... here goes ...
    I have a raw 12 inch ELO touch scren that I will be fabbing into a console in my truck. It's working well at 800x600, BUT the image goes all the way to the screen edge. The problem is that the TS is not active for a small edge around the screen. A MAJOR hassle, since every Windows app has the CLOSE button on the top right ... right where I can't get TS.
    Is there a tool or something that will let me "squash" the screen a bit?
    (Put "black bars" around the edges perhaps?)
    The display has some adjustments, but not anything to let me "shrink" the display.
    Any input will be greatly appreciated!
    Thanks!
    ... Mike ...
    Dec 2005
    Raleigh, NC
    Try using PowerStrip to do it. That'll get the job done.
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    Normally displays let you set the horizontal and vertical size along with the position. Are you sure yours doesn't?
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Jan 2006
    Thanks for the info so far ... I;ll look into Powerstrip tonight.
    As for adjusting the monitor, I tried but thereis no setting to reduce height and width. It works TOO well, the autosync sets it at a crisp viewing range side to side ... I could not adjust ot to compress.
    Cheers!
    ... M ...
  1. Dual Display Problem on M-II w/PowerDVD
    By DrDeriv in forum General Hardware Discussion
    Last Post: 04-11-2005, 05:16 PM
  2. Replies: 2
    Last Post: 03-01-2005, 12:59 PM
  3. Stupid Xenarc! It won't turn on when laptop is on or display correct!!
    By PDiddy in forum General Hardware Discussion
    Last Post: 01-17-2005, 07:53 PM
  4. display, projected to the windshield
    By leon_id in forum LCD/Display
    Last Post: 02-23-2003, 03:32 AM
  5. 4sale 2x20 Futaba vfd display
    By Ted in forum Classified Archive
    Last Post: 05-12-2001, 07:47 AM
