For one, I would run the lilliput off of a regulated 12volt line.
Also, I would also not connect it to the remote line.
If you want it to turn on automatically when it recieves power, and to shut off when you turn the car off, you could connect the power to whatever power supply you use (i.e. an opus 150w) and go from there.
When you originally cut the wires, did you check to see which wire was the 12v line and which was the ground?
If you did arbitrarily choose a wire for the ground and 12v, the lilliput most likely has built in polarity protection that would fix that error.
However overtime it could begin to wear on components (my opinion who knows if thats true)
LinkBack URL
About LinkBacks
