If you want GPS i'd get a 6inch min screen. Anything under that you will have a hard time seeing. My friend tried it on a 5inch and it was doable but not pretty.
I've seen gps software that will show the map with directions along with tell you when to turn via the sound card. A very nice option so you don't have to take your eyes off the road. I'm not sure if any computer software will do that since I haven't looked into it.
As for what to look for. Go with a VGA screen if you want to spend at least 300 for the screen and the controller. If you want to get a RCA input screen then you can spend a min of 100 up to 300. The one thing to look for in any screen is the brightness and this will be messures in nits. Look for anything around 200. A lot of cheap screens will be around 70 i think? and they suck in direct sunlight.
If you go with a VGA screen you use a controller card if you go the other option its a tvout card.
As for theft, I have mine on a arm that i can just slide off and place it into the center console when I leave my truck. I only use it on long trips anyway. As for sun.. just keep it out of direct sunlight.. there are many ways to do this.
LinkBack URL
About LinkBacks
looking at the res of my 5.6inch I think GPS should be okay...... assuming the map is zoomed into a decent level of course, but when driving u probably dont want the map zoomed out like crazy anyway....
