Results 1 to 10 of 10
Thread: lilliput monitor not diplaying anything
    Apr 2006
    i am running wires from the black and yellow wire on my opus power supply to a barrel plug that plugs into the monitor. when i turn on the screen i get power. but the only thing that displays is a couple of blue,green, and red dots. but then i bring the screen inside and plug it in the wall it works normal. whats wrong?
    Mar 2006
    Colorado, but Canadian!
    you sure you have the polarity correct?
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2006
    no im not sure, how do i check?
    Aug 2006
    Wont it become an expensive paper weight if the polarity is wrong?
    Mar 2006
    Quote Originally Posted by SentraVIP View Post
    Maybe. If it has reverse protection, then no. It could give an error signal or nothing (sort of like what we have). I wouldn't go and start reversing wires without checking first though, because if the polarity is correct, and you switch them, and the reverse current protection circuit is broken/missing, then you will have a nice smoke show, some coordinated music pops and a paperweight.
    So. Check the wall transformer, or the back of the screen and you should see something that looks like a circle with a line coming off encircled by a semi circle. One of these should have a "+" or a "-" by their respective lines. Then if the center one is positive, make sure the wire that connects to the center terminal is being fed the yellow wire from your PSU.
    Apr 2006
    Quote Originally Posted by 2k1Toaster View Post
    well i checked the positive and negative with a mutlimeter before i plugged it in and they are correct. if they were reversed, the monitor would not turn on at all right?
    Mar 2006
    Quote Originally Posted by MuDvAyNeDude122 View Post
    Well it depends on how the monitor was built. Some will just flash one colour, some will turn on but blank screen, some nothing, some go kablewee!!
    Apr 2006
    well if the positive and negative are correct right now, what would be other causes of it not working properly.?
    Aug 2006
    Did you plug in the VGA connector to the same pc both times? Maybe it's the VGA port or something?
    Just a suggestion...
    Apr 2006
    well im not even plugging it in with the vga, but when i plug it in through the wall outlet without the vga it still displays words and stuff, but when i plug it in my car i get a few red, green, and blue pixels and the screen keeps getting brighter and brighter the longer you keep it on.
  1. Replies: 118
    Last Post: 10-22-2010, 03:05 PM
  2. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 06:26 PM
  3. Replies: 88
    Last Post: 09-15-2004, 05:38 PM
  4. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 08:41 PM
  5. Replies: 5
    Last Post: 04-01-2004, 04:37 AM
