Results 1 to 3 of 3
Thread: URGENT Touchscreen a bit of smoke is it broken?
    Variable Bitrate Philhop's Avatar
    Apr 2006
    Angry URGENT Touchscreen a bit of smoke is it broken?
    I just made a new stainless surround for my touch screen the image was a little funny so i wiggled the ribbon this fixed it! , but then after it blew a fuse in the car , So I replaced this fuses .. Second time there was a little smoke come out the back ... And I know letting the smoke out is bad?
    Will this meen that the unit its screwed or would the be a way to fix it , This is a very sad day for me
    Please Help !
    my TURBO! Altezza!
    ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    sorry to hear that.. smoke is always bad..
    is the monior still working? if yes check everything again... something is shorting. first time it blew a fuse, second time it started blowing somthing else that was acting like a fuse.. you should always replace the fuses with the same max amp fuse
    Apr 2006
    Yes I did replace it with the same fuse , but in doing this wriggling the ribbon on the board caused the screen to smoke from the back of the controller... I wonder if you can just buy another controller unit as the screen and im sure touch screen controller is fine
    Short Answer Monitor is broken at the moment!
    my TURBO! Altezza!
  1. BMW 540 Touchscreen Complete!
    By sajid753 in forum Show off your project
    Last Post: 04-23-2007, 04:52 AM
  2. 2003 Saturn L200 In Dash Touchscreen Carputer
    By snoslicer8 in forum Worklogs
    Last Post: 07-11-2006, 09:57 AM
  3. FS: 8.4" LCD with USB touchscreen
    By lzrdkng14 in forum Classified Archive
    Last Post: 05-28-2004, 03:40 PM
  4. Broken connector on my VGA touchscreen!!!!
    By tommyd75 in forum LCD/Display
    Last Post: 04-05-2004, 06:08 PM
  5. WTB: (or trade) 8" 18 bit touchscreen
    By SuperMatty in forum Classified Archive
    Last Post: 04-11-2003, 11:08 AM
