Results 1 to 8 of 8
Thread: Replacement ribbon cable for Lilliput 7"?
    Newbie bdqpdx2000's Avatar
    Cranbury NJ
    Question Replacement ribbon cable for Lilliput 7"?
    Any idea where I can find a replacement ribbon cable for the Lilliput 7" touchscreen? This ribbon cable connects video from the board to the screen. Picture:
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Also mp3car store and mouser. You want a FFC with same side connectors for the 619 (I believe, never owned one), and opposite side connectors for 629. The mp3car store says it sells one for xenarc, but it simply means it's an opposite side FFC (so it'll work for lilli 629).
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Oct 2006
    Quote Originally Posted by psyrex View Post
    not on my 629. they're on the same side.
    don't let my reg. date fool you; 'lurker since '03.
    banned - scammer 97GST's Avatar
    Mar 2006
    Tijeras, NM
    I bought a 300mm brand new cable through Armen at DigitalWW.com and his shipping and packaging was grease lightning! A+++++! Buy from him, you wont regret!
    1998 Mitsubishi Eclipse GS-T
    ABIT NF-M2 nView | AMD Athlon64 FX62 Windsor | nVidia GeForce 6150 | Realtek ALC883 7.1DTS | Vista x64
    RF Power T162S | RF Power T162S | 2x RF Power T212D2 | RF Power T8004 | RF Power T20001bd | RF 3SIXTY.2
    Jun 2005
    Oakland, CA
    Quote Originally Posted by majidaldo View Post
    Whoa, really? The 629s aren't all the same? Thats scary. I doublechecked mine, and it's definitely opposite side.
    ...it never ends
    Mar 2006
    Tijeras, NM
    Maybe thats the problem with my setup... The unknown pcb controller I have is probably a 629 controler and the other one is a 619. The 619 just probably doesn't work. hrm, I guess it wont hurt to try.
    Oct 2006
    Lightbulb
    i bought the transreflective and it says 629gl on the box. what happened was i messed with the cable so much that i forgot what kind it was. but it looks like same side judging from the remains of my cable. notice the blue lettering is on the same side in the picture.
    now i bought the opposite side ribbon from the mp3.com store based on advice here. when i use it i can only manage a purple image when i slightly lift up the ribbon on the controller end. when i look closely in the socket, i can see pins both up and down like it wouldn't matter which way the ribbon is inserted.
    UPDATE: BINGOOOOO!!! i used the opposite faced cable from the mp3.com store and modded it to a same side faced cable. method:
    1. i used a BLUNT box cutter blade to peel off the black plastic strip. i peeled it off one small piece at a time. i did this on a flat surface. the conductors on the other side should be safe when carefully done.
    2. i used the blade's edge to fold over the conductors. the edge was exactly behind where the conductors start. i did this in carefully in several stages in order to get a perfect fold.
    3. once i folded it back as much as i could, i proceeded to further flatten it between two flat surfaces. be careful not to make any rubbing motion; you just want to flatten it.
    4. eventhough i broke off my clip on my controlled, i was able to snugly fit the cable in the connector. if it doesn't fit go back to step 3. you should feel it go in a few millimeters.
    5. i taped it down and added the toothpick method just to make sure.
    sorry no pics since im afraid of ruining my connection! having said that, the Parlex cable is WAAAY more robust than the cable that came with my monitor. there are two potential failure points on it: where the plastic strip meets the ribbon. i actually prefer my modded cable. it's working with a sharp fold in it! i would never be able to do this with the original cable.
  1. ribbon cable DWW-700M
    By i_VTEC in forum LCD/Display
    Last Post: 10-17-2006, 09:29 AM
  2. WTB: Lilliput 629 Ribbon Cable etc..
    By chicagoninja in forum Classified Archive
    Last Post: 07-04-2006, 12:09 AM
  3. Where to buy Xenarc ribbon cable
    By dmurray14 in forum General Hardware Discussion
    Last Post: 05-04-2006, 10:06 PM
  4. I need a longer Ribbon Cable for 7" Lilliput
    By ovsims in forum LCD/Display
    Last Post: 04-30-2006, 11:07 PM
  5. lilliput digikey replacement ribbon part #
    By netboy in forum LCD/Display
    Last Post: 10-26-2004, 11:41 PM
