Results 1 to 4 of 4
Thread: Help on LCD screen
    Jun 2002
    Sweden
    Help on LCD screen
    Hi !
    I'm just in the process of starting my Car entertainment system, and i have a couple of question on what LCD screen to choose.
    i though about a 5-7 Inc screen TFT, I want to be able to use it as a touch screen to avoid keyboard or mouse. I want to be able to watch DVD, DIVX, play Games , use it for all the normal computer usage.
    I has to be able to display TV signal as well, also be visable in daylight and in good resolution (for games )
    the questions !
    What are the things I need to consider when I look for a screen ?
    I of course want it as cheap as possible, but I'm prepared to pay a little extra to get a good one.
    Please help , sice I have never worked with LCD's before so I don't know all the info and things I need to consider.
    Thanx !
    Conny from Sweden
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    Here is my general rule of thumb. All the tft's are basically the same res as all the others. Here is the specs on mine..
    Dot Resolution: 269.568
    Active Area: 138.24 (W) x 103.43 (H) mm
    Screen Size 6.8" Diagonal Length
    Brightness: 250 nit
    The first two are pretty standard with any tft screen around 6-7 inches. The big one that would should look for is the brightness and this is measures in nits. Anything over 200 i consider very good and should see it pretty well in direct sunlight. A lot of the cheap ones will have i think 80nit. I'd rather spend a bit more money on a bright screen so i can see it in the daytime.
    '98 Explorer Sport
    80% done
    Jun 2002
    Sweden
    Ok, but what about resolution ?
    640 * 480 or 800 * 600
    because otherwise I will have some issues reading the icons in the OS ?? Or am I wrong ...
    Thanx for the reply
    Jun 2002
    Sweden
    btw hijinks21 where did you get your LCD ? Do use a Digital Graphic card or just Composite or TV-Out.
    Gunnt
