Results 1 to 9 of 9
Thread: Xenarc 700tsv bsod? help.
    Mar 2005
    Unhappy Xenarc 700tsv bsod? help.
    greetings.
    i've never had a problem w/ my touch screen before. i took apart my xenarc and mounted it into my dash voiding all warranty i had (i think). today when starting up my carputer, the xenarc led green light comes on, but doesn't show anything in the lcd pannel.
    after troubleshooting it and spending an hour w/ my dash in pieces, nothing has changed. whenever the xenarc gets power, the led goes on and won't turn off. it doesn't blink, it's just always on and shows a black screen. the letters telling me what hz and resolution don't even come on.
    any help? i double and tripple checked all the wiring in the back. when the issue first happend the ribbon belt had fallen off, but i put it back in and this still happens. this happens even if nothing is plugged in but the power...
    help please. or tell me the right words to search cause i cna't find this and xenarc support isn't open on sundays...
    Mar 2005
    just called xenarc - said that it was probably my control board and i could send it in w/ a check for $115 and get it fixed. i might end up driving over there being that it's kinda attached to my double din dash insert.
    said that they used to have a problem similar to this in which the F1 fuse would blow - looks like i get to go find a multimeter for a little fun
    anyone have any other ideas of what it could be? or is there a cheaper way to fix this?
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    Hopefully I can save you some time here - Make sure that you plugged in your touch screen controller correctly. Here is a pic showing it plugged in correctly http://www.mp3car.com/vbulletin/atta...1&d=1162867189
    4 wire connector should be aligned to the right of the touch controller connector.
    Armen
    Quote Originally Posted by Cerztrueheart View Post
    Mar 2005
    @digitalwww
    thanks for the input, unfortunatly those wires are connected and in the right spot.
    Sep 2002
    ILLINOIS
    what if you unplug the touch controller completely, does it still behave the same?
    @digitalwww
    Mar 2005
    same happens. can anyone tell me where i can get a touch controller? or do i just need to send it back to xenarc and hope they can fix it while it's out of warranty?
    Sep 2002
    ILLINOIS
    On some of these I noticed that the main chip (big one in the middle of the board) is not soldered properly and some of the legs are not touching the PCB. You might not have this but take a look. You can slightly bend the PCB away from the chip and look at all the legs on all 4 sides. You will need a good eye.
    Armen
    Low Bitrate fiveslo's Avatar
    May 2006
    Land of Lincoln, IL
    I have a similar problem, however not so grave... anyways does or can anyone give any advice on how to reset the touchscreen to factory default? The reason I ask is my Xenarc 1040TS, powers up and displays correctly, however the touchscreen portion of it is acting completely haywire! I am running Streetdeck software as the front end, however have lost all control of the touchscreen! I can't get into the touchscreen calibration software since I've told Streetdeck to startup and shutdown WinXP automatically... Help..How do I reset the touchscreen????
    Mar 2005
    aite, back from my long departure and tired of using my ipod as my car stereo. called xenarc and getting a RMA faxed back right now.
    i'll keep this post updated with progress incase anyone else has a problem.
  1. Xenarc 700TSV, Xm Direct, etc for sale
    By Zinjamaster in forum Classified Archive
    Last Post: 10-02-2006, 08:57 AM
  2. Xenarc 700TSV 7'' touch screen
    By krazymarine in forum Classified Archive
    Last Post: 09-20-2006, 11:55 PM
  3. Pandora w/ Xenarc 700TSV and Barrel Connector
    By froalskiner in forum General Hardware Discussion
    Last Post: 07-20-2006, 03:39 AM
  4. Replies: 7
    Last Post: 11-09-2004, 03:33 AM
  5. FS: Xenarc 700TSV touch UXGA capable
    By cproaudio in forum Classified Archive
    Last Post: 01-20-2003, 07:38 AM
