Laptop drives definately have 44pins if its standard 2.5" ide. If thee are pins left over when you align the plug with the header it must contain more than 44 pins or the pins are not spaced the same, which if thats the case its not going to fit.
If, on the other hand, it does fit and and you wire up the other end correctly there is no reason why it shouldnt work.
LinkBack URL
About LinkBacks
