Well I think you bought a 7" screen right? Are you aware that the screen and casing combined is bigger than a din width. So There will probably need to be some modification. Good luck though.
I'm starting my Car PC soon but i'm having problems deciding on how to install the LCD touchscreen.
i listen to FM and AM radio a lot so an aftermarket HU is a must for me... Also I really really want to keep the HU Cover so that why i can't use an indash motorized lcd. The car is pretty new and i cannot custom fab it with bondo or fiberglass since i have no prior experience with it and would not like to practice on my new car...also i really don;t want to use the pci radio as the reception i heard is not that great... anyways
I just bought this
ive been researching all the different installs on this forum for the past few years now and this is the best setup i can think of for my situation
VS
The first setup requires the least amount of work and is easiest for me all i have to do is build a Single DIN enclosure with sliding rails attached to the LCD case which has mounts already built in so that means i won;t void the warrenty. Also i was tihnking of using a couple of servo motors to motorize it...the only bad thing i can think of is it won;t look OEM....
-The second setup is a tons more work which involves taking apart the LCD screen to fit it in a smaller housing which will void the warrenty... I would also have to extend the lcd screen out more so the lcd would lower enough to install a Single DIN HU instead of the DVD drive you see there.. I really like Jetkit's idea for mounting but i don;t know if all that work is worth it...
Anyways this is the only valid LCD installations i can think of for my situation...
1.9in x 2.9in -- 47mm x 73mm
actually it fits perfectly just waiting until i get my HU next month to test fit everything
