Results 1 to 5 of 5
Thread: New Xenarc- Do I have a problem or is this normal?
    Jun 2004
    Vienna, Austria
    Hey guys,
    I finally made the plunge and bought a basically new 700TSV. It was originally bought in march of 06, and according to the guy his CarPc project never got off the ground. No visible wear whatsoever, so I believe him that he only tested the monitor twice. Seal on backside is fine.
    It is supposed to be a special model with "High brightness enhancement" from Mini-tft.de. I have the original receipt for about $820
    Now when I power it up, I can see two bright spots that always pop up in the same stop (top left and top middle) as soon as I put light pressure anywhere on the front or back. You can see them in the pics as white dots, kind of hard to capture them on camera.
    While the rest of the screen looks good, for the money I think this is a real PITA. Is this normal or do I have a problem?
    Thanks,
    Lukas
    Sorry for the blurry pics, all I could do without light.
    Aug 2006
    Valencia, CA
    Weird, looks like something is pressing on them from the back side or maybe around the edges out of sight.
    I have a 700tsv and dont have anything like that.
    Jun 2004
    Vienna, Austria
    Yeah, thats what I thought. It is only in those two spots, no matter where I touch it.
    I am wondering if its has to do with the "high brightness enhancement". Maybe they changed out the touchpad or something and somehow screwed up the install.
    I am just glad that I haven't opened the cover yet, I guess there should still be a warranty on it.
    Jul 2006
    dust between screen and touch panel
    I had this problem when I took apart a in-dash lcd screen off ebay when the touch screen stopped responding. I wasn’t to careful about keeping the panels dust free and a small but unnoticeable amount of dust was between the screen and the touch panel and puts a pressure point on the lcd like of you pushed a pen on a normal lcd screen. If you take apart the screen very carefully and just use a screen cleaner wipe or even a can duster it should remove the dust partials and stop the pressure points form distorting the screen.
    Jun 2004
    Vienna, Austria
    Thanks, but I am definitely NOT taking it apart... until the warranty expires! At least now I know that this is not normal.
    I just spoke to the seller and he was not aware of the problem. We agreed that I will contact the company he bought it from and see what they will say. Worst case he will take it back.
    I'll let you guys know when I have news. For a $820 monitor I definitely expect more quality!
  1. Not your typical flicker problem
    By JPuma in forum LCD/Display
    Last Post: 05-30-2007, 10:28 AM
  2. Xenarc white-screen problem after bezel swap
    By dune in forum LCD/Display
    Last Post: 05-10-2006, 08:43 PM
  3. Config Problem with Xenarc.... PLEASE HELP
    By Mike2003Cts in forum LCD/Display
    Last Post: 03-29-2006, 05:09 PM
  4. Replies: 1
    Last Post: 07-15-2005, 09:58 AM
  5. xenarc 700tsv problem
    By dannn in forum LCD/Display
    Last Post: 12-31-2004, 02:34 PM
