Results 1 to 10 of 15
Thread: Small 480x800 LCD Panels
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    I'm trying to find a 480x800 LCD Panel smaller than 100x160 or if that is not possible smaller than 104x165. Note, it is just the LCD panel I am interested in.
    I've made a table. Mail me if you got additional info.
    http://members.chello.se/bengt-olof....chLCDwith7inch
    Sofar it seems that it is only AU Optronics A070VW01 (or maybe C070VW02) that fits the bill. But on that panel the flexible board comes out in such a way I have to bend it quite hard. I'm a bit reluctant to do that.
    Can you help me out?
    Regards, B-O
    Sep 2005
    Stockholm, Sweden
    I've got word that there is a 6.5 inch Sharp LCD panel with 480x800.
    It would suite me perfect. 500nit. But it is discontinued!
    Has anyone got any info or experience of Sharp LQ065Y5DG02?
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    Quote Originally Posted by bes51659 View Post
    Regards, B-O
    i want to know if you have any links (other than the one above) for a touchscreens between 5 and 5.5 inches wide?
    thanks
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
    Sep 2005
    Stockholm, Sweden
    Not specifically no. Sorry. But htere's a few good ones on the link provided. And if that is not enough pick some of the panel product id's on there and google them. I remember I've seen some smaller panels around. None with greater resolution than 234x400 though. Good luck
    <edit> there is a 5.8' screen from Toshiba called LTM06C381. Smallest one I've found with 480x800. Dimensions 135.8x88. But the price I saw was 900USD!!!! Can't be right.
    Sep 2005
    Stockholm, Sweden
    I've got hold of a few Sharp LQ065Y5DG02! Not easy. The first one will cost me 400USD but the third 250.
    Anyone interested? Mail me right now and get the price down!
    Note! I do not leave any guarantee that it will acctually work ;-)
    Nov 2006
    Huntsville, AL
    Hi All,
    I've been lurking for a bit while I decide what I components I want for my in-dash PC. My goal is to fit everything into a double-din chassis, and I'd like to have physical buttons and perhaps a rotary encoder for menu selections, etc.
    With my self imposed space constraints and requirement for buttons, I've been looking very hard for a good LCD that is smaller than the widely available 7" touch panels.
    I have found the Mitsubishi AA043MA01 display:
    4.3" diagonal
    103x63 mm case size
    800x480 resolution
    130 degree viewing angle
    500:1 contrast
    200nit brightness
    $180 price point
    The display is listed on the All American site as an Optrex display, but I suspect that is a typo. The site's part-search tool doesn't show the display, so I guess I'll have to call them on Monday.
    It appears that the backlighting is done by LED's instead of CCFL. The brightness is pretty low at 200 nits, but with the lack of available transflective displays, I had planned on doing my own backlight upgrade anyway. Since I have a lot more experience with LED lighting, this panel might be a great candidate for an upgrade.
    I've done a fair amount of searching, but can't find any other vendors for this panel. It also isn't mentioned anywhere on the Mitsubishi site. If anyone knows where I can get one of these panels, I'd really appreciate any help.
    Thanks,
    pb
    EDIT: I deleted my extra posts. For some reason, vB refused to display this post, so I posted again... And that one failed to show, even using a totally different browser. So I posted the 3rd, and it showed. Now I come back and all 3 were here. POS vB.
    Sep 2005
    Stockholm, Sweden
    Thanks PB, but 4.3 is to small and 200 nits is way too dark.
    There is also a 5.8 Toshiba but that is still too small.
    This is where it has to go:
    So you see, 6.5" is *perfect*
    Nov 2006
    Huntsville, AL
    Hi bes51659,
    I'm glad you found a screen that works for you, but I was thinking that you could add the screen to your table so others know it's available.
    The brightness is low, granted, but if I buy it I'll likely be upgrading the backlighting. I'll probably be getting a 7" screen for the short term, but in the future, I'm going to want buttons and knobs for control purposes, which means a smaller screen.
    It seems crazy that 7" touchscreens with VGA/Composite input are only $200, but a bare 5" panel can run up to a grand.
    pb
    Aug 2006
    New Ro, NY
    Quote Originally Posted by pbarrette View Post
    Hi All,
    4.3" diagonal
    103x63 mm case size
    800x480 resolution
    500:1 contrast
    200nit brightness
    $180 price point
    Thanks,
    pb
    sounds like what i'm looking for.... are you the person selling the screen or do you have a link?
    is this just an LCD or is it a VGA?
    I'm searching for an LCD (VGA if possible) (just under) 5.5" x 3.5
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
    Sep 2005
    Stockholm, Sweden
    Hi bes51659,
    pb
    Done. Did not know anyone looked at it :-) Cheers!
  1. looking for a small lcd 2.5 or 3"
    By b15ginz in forum Classified Archive
    Last Post: 03-29-2005, 11:39 AM
  2. LCd panels and winter time...
    By multiplexor in forum LCD/Display
    Last Post: 04-28-2003, 11:50 AM
  3. small proggy to shut down my lcd?
    By etrik in forum Software & Software Development
    Last Post: 12-30-2002, 12:16 AM
