I was also wondering the differences in the two touchscreens. Is the 629 a newer model? I didn't see any striking differences between the two units specs. Did I miss something?
Does anyone have any pros / cons for each monitor?
ScAndal
The 619GL is flat on the bezel, while the 629 is curved. I believe the aspect ratios are different (15:9 vs. 16:9)
Are the controlers different? Cause I have a controler here that hooks up to the hitatchi lcd but wont plug up to the 619-7 buttons
1998 Mitsubishi Eclipse GS-T
ABIT NF-M2 nView | AMD Athlon64 FX62 Windsor | nVidia GeForce 6150 | Realtek ALC883 7.1DTS | Vista x64
RF Power T162S | RF Power T162S | 2x RF Power T212D2 | RF Power T8004 | RF Power T20001bd | RF 3SIXTY.2
does it really matter which one i get if i have a premolded dash console with the bezel for a 619 does it matter if i get a 629?...since im removing the bezel and using the one on my dashconsole which is already molded in...just want to clarify because the store is sold out of 619s and i wanna order one bad and they only have 629s in stock
The 629's bezel is flat while the older 619 is curved. As fas as I know from comparing mine and my friends, it is exactly the same except for the connection in the back. If you are going to take the bezel off anyway, either one would work.
