Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: Improvised sunlight readable
  1. #21
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I broke one of the white tiny clip (one that hold the ribbon to the panel) on the Super/Avatar screen by using tooo much force while pushing it out. The clip is okay, it just the "hook" that keep it in place that broke. I tried to use piece of soft, thin, flexible plastic (got it from hanging file folder). Cut to shape, sand one side to thinner a bit more and jamp the darn thing down. Work like a charm.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #22
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by MatrixPC View Post
    Cool to know it worked, that's what I was getting at with the "wedge" of plastic. Bet it's the same damn clip holder too .
  3. #23
    Newbie Blazenhazn's Avatar
    Jun 2005
    Just curious, you said you ordered a 2-way mirror? What did you order? Is there like a 2-way film that you can buy?
    Lexus GS300
    Old setup - 10.4 non-touch, Media Center 2005, Biostar M7NCG, AMD Duron 1ghz, M1-ATX
    ..Moving on to something MORE PRACTICAL :)
  4. #24
    Apr 2005
    Boston, MA
    Quote Originally Posted by Blazenhazn View Post
    Don't know if you can get a film that's comparable, I'm sure you can but it might not be something you could normally buy. I mean, I'm sure 3m makes something like etc.
    I got it off ebay, perfect size for the 8" lilliput (I may need to trim an 1/8" in one place), but I haven't had enough time to experiment with it, you might want to hold off (or not ). It was around $20 FYI
  5. #25
    Oct 2004
    Sydney, Australia
    looking forward to seeing if this works.
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
  6. #26
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Im interested in seeing the before and after pics of this mod. Whether it works or not, itll be interesting to see the results =)
    Also, where do you get that 3M film? I went on their site and requested samples, but I havent gotten a response. =(
  7. #27
    Variable Bitrate red_parchel's Avatar
    Jul 2006
    Boston, Ma
    If your white clip is still broken i can say that i've fixed such clips on my ipod with hot glue, just put the ribin in and hot glue it in place
    MobileThree: in car - Zotac Atom/ION - linuxICE 2.0.2
    --worklog--
  8. #28
    Apr 2005
    Boston, MA
    Quote Originally Posted by red_parchel View Post
    The reason I haven't played with it more is I needed to get some other stuff done and (a break before I got to frustrated).
    The problem with fixing it with a wedge or similar is that it's so tight, simply trying to adjust anything inside the lcd causes it to come out which makes trying to play with films etc, maddening because I can't get an image on the screen.
    I'm thinking of ordering some high output ccfls too. I have to hit a local neon shop to see if I can persuade them to shape it. I could give it a try, but they bend glass all day.
    I also think adding some reflective foil to the outer upper area of the ccfl would help a lot. Right now, that light probably gets mostly absorbed by the case.
  9. #29
    Jun 2005
    any progress on this?
    Lexus GS300
  10. #30
    Apr 2005
    Boston, MA
    Not yet, got sidetracked by my b-day this weekend.
  1. 10.4" sunlight readable touchscreen
    By DCS in forum Classified Archive
    Last Post: 10-18-2006, 03:01 PM
  2. Replies: 16
    Last Post: 10-24-2004, 05:52 PM
  3. Sunlight readable LCDs
    By Chairboy in forum LCD/Display
    Last Post: 06-12-2004, 04:13 AM
  4. Replies: 10
    Last Post: 02-08-2004, 02:20 PM
  5. Need 7" sunlight readable, Apollo or other...
    By Olli.D in forum LCD/Display
    Last Post: 10-16-2003, 04:00 PM
