Results 1 to 10 of 15
Thread: toutchscreen playing up. keeps going blank!! **HELP**
    Oct 2006
    north wales
    hey guys, im having some trouble with my 7" monitor. it doesnt have a brand name on it or in the manual. but it does say it model number, which is: XDXP070Z
    now, when i first got it i tried it on one pc. and it was showing the screen but the after about 2 seconds it would go blank. the power was still on, and i could even go through the video inputs back to VGA, and it would show the screen.. but only for a couple of seconds, then go blank.
    SO
    i took it to another pc in the house with the same car battery. and plugged it in and it worked FINE.
    i then tried it again but on my own pc, and again.. it worked fine.
    but since then it has been back in its box. but now i have the rest of my car pc. i got it out and tested it. and the bloody thing has gone back to displaying the screen for a couple of seconds and going blank again. the same as when i first tried it.
    but i have tried it with the two pc's that it worked with before, but no joy. still the same thing.
    anyone know why this might be happening? or what i could try?
    Thanks!
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Sounds like perhaps a loose cable or connection. If you can;t find anything, it is possible that the controller card has gone bad. Check all connections, make sure you have enough voltage and amperage AT ALL TIMES during operation, and open the unit and make sure everything is seated correctly.
    Michael
    Oct 2006
    north wales
    well i know the VGA cable is all there, because when i dissconnect it after its gone blank, it flashes DISCONNECT for a couple of seconds then goes blank!!! this is really annoying..
    Dec 2005
    is it possible tha its going to the sleep mode(power save) for some reason ?
    if you can find some way to reset the settings, it would be worth to try. (generally it is some key combination press & hold at power up)
    Oct 2006
    north wales
    hmm, i'll have a play. im most confused though because it worked after just moving the stuff to the second computer i tried it on.
    Oct 2006
    north wales
    ok.... wtf. i just tried it again and its now working.. i have done NOTHING different. soooo confused!
    Oct 2006
    north wales
    cuold it be that theres a battery inside that needs to charge before it can switch on properly, because that would seem to tie in with whats happening at the mo.
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    get a new cable maybe? it could just be soethign as simple as that,
    if its a lilliput, i have a spare cable i can send to you for a few bucks
    or you could have just not connected the wire well, thus causing the monitor to connect and disconnect to the vga signal... and when you moved it around, it could have just put it in a place where the connections are always there...
    but without being there, i could never be 100% sure
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    Oct 2006
    north wales
    no, im 100% sure all the cables are fine. im pritty sure now that all it is.. is that you have to have it connected up to the battery about 2 mins before turning it on. must be a capasitor or something
    Dec 2006
    Smile
    I've got same problem like you, but my monitor diff model of your
    it make me crazy a week.
    So i'am just do this:
    - wiring GROUND rail directly from car battary (- connecter) to one of black cable output from M2-ATX
    For me i'am do only this all of my monitor problem was fixed.
    Hope this can guide you for fix your monitor problem.
    Sorry for my poor Eng.
  1. Lilliput 619 Blank Sreen?? HELP
    By Shmeker in forum LCD/Display
    Last Post: 11-28-2007, 11:54 PM
  2. Playing DVDs
    By dovla in forum Road Runner
    Last Post: 05-23-2006, 07:12 PM
  3. xm and mp3 playing at the same time
    By bswift in forum Mobile Impact
    Last Post: 01-15-2006, 05:19 PM
  4. Voice Recognition Whilst Playing Music?
    By konnichiwa in forum Software & Software Development
    Last Post: 09-30-2005, 02:54 PM
  5. Having trouble playing video
    By Keebortz in forum General Hardware Discussion
    Last Post: 07-27-2005, 08:18 AM
