Results 1 to 7 of 7
Thread: Help Understanding Lilliput USB
    Dec 2006
    Hello,
    I was recommended to this site from cinemaronline. I would like some help understanding the usb connection. I am currently connecting to a PC through the VGA adapter and the 12v power cable. I can not get the system to recognize the monitor as far as the touch screen portion. I get the normal PC windows screen, but have to do everything with the mouse. I noticed on this forum that the usb on the monitor is not actually a usb. How do I get the system to recognize the touch screen? I also have downloaded the newest drivers. It is the 8.4' screen.
    Thanks JR
    Feb 2006
    Vancouver, BC
    you need to connect the USB to your computer. A monitor is simply an output device. Your touchscreen is an input device and it communicates with the computer via the USB.
    Dec 2006
    Hello,
    Thank you for the reply. I noticed in the main forum about Lilliput that the USB plug is not truly a USB?? Is this correct?
    Thanks JR
    Elsewhere
    Yes, it's a USB connector.
    I'd like to knwo where you got this information, as it's wholly inaccurate.
    How about the Wiki?
    Jun 2006
    You are mistaking the different "USB" connections on the lilliput. The one that is 9" off the end of the VGA cord is a USB connection. Just plug it into your USB port on your computer. That's what it's meant for. The "USB" on the back of the monitor is not a true USB connection. This thread says it's for Aux Inputs.
    Dec 2006
    Hello,
    I received this info from here:
    FAQ: Everything you need to know about your Lilliput
    Thanks JR
    Nov 2003
    Connecticut
    that usb = not true USB.
    that usb = true USB
    hope that helps.
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. Lilliput TS (usb) problem
    By steele1976 in forum LCD/Display
    Last Post: 09-24-2005, 08:58 PM
  3. Lilliput USB Circuit Board...
    By gleinz in forum LCD/Display
    Last Post: 01-18-2005, 05:09 PM
  4. lilliput kills USB GPS
    By johnymd in forum LCD/Display
    Last Post: 10-07-2004, 02:42 PM
  5. LILLIPUT Solder the USB cable etc..
    By darthvinh in forum LCD/Display
    Last Post: 06-17-2004, 05:48 PM
