Nislo, u you seem experienced with the EBY701. Is there a auto switch feature, for like rear view cameras?
thanks guys for all your import i got it to work just fine a few things i noticed while working whit it is that the blue button lights need to be off before you press 588998 then once you press in the number on the remote press the menu button on the screen itself not the remote. then use the left and right arrows next to the menu button on the screen to navigate up and down then use the volume buttons on the screen to change the values after you get done press menu again to exit and your done no soldering what so ever![]()
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
This screen does not have auto switch, but I have made a mod to do it. Someone told me the BRCk has something to do with when the car is moving it turns off the screen so the driver cannot view it...
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
hey fellas, I in the process of configuring the auto on for my eby701 and am having some trouble. I manage to get to the screen where the options for power mode and set it to 1 but after I cut the power from my ignition and reboot the pc, the screen does not auto power. I check the option power mode again and notice it got reset back to 0. Why and how...?
Here is my steps to get to the option:
1. after all the powering off and on with the battery and unit itself, boot it up and enter 588997
2. I get a language screen, on the language screen I press the menu button on the unit itself not the remote to get to the power mode screen.
3. Change power mode from 0 to 1 and press menu on remote.
also after all this is done i repeat the steps to check if the option stayed and it did. But when I turned off the ignition and turned it back on the unit did not auto power. I went back to check the option and it reset. What am I doing wrong. Thanks in advance.
Just to let you all know, worked on my eby701 - Although I didnt get the ------- screen, I did get a language select screen, pressing the menu button on the unit got me to the right screen though,
Power setting 2 is auto power on btw works a treat![]()
thanks for all your info... I finally got it too work don't know how but after many tries, the option stayed and it auto power every time i start up my car.... my car pc is finished and will be posted soon in the showoff thread. look forward to it
how the hell do yo uchange power mode from 0 to 1 or 2?
ive gone to it and pressed 1 on remote, and it just makes the menu dissapear? ive pressed volume + and - on it, it does the same
These codes work on the 889GL as well (8" lilli). Just so you know.![]()
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
