Results 1 to 10 of 14
Thread: BAD Experience with PYLE Gooseneck LCD mount.
    Newbie Autonator's Avatar
    Oct 2006
    Houston, TX
    Bought a PYLE gooseneck LCD Mount that screws to your passanger seat bolt. It is the perfect solution only if it was built with stregth considertations on its joints.
    first the two screws on the seat bolt clamp that the gooseneck attaches to became loose, looks like they are always loose cuz those screws dont possibly have a holding power strong enough to stablize the goose neck when a LCD is attached on the mount. It must be a weld not a screw joint. result is when i installed it, the LCD with the whole mount has a half an inch movement right and left while turning your car. second,
    After a few days of use, the goose necks second joint on the bottom becomes loose.. result, the whole LCD with goose neck falls down to the floor.
    that reaaaaaly sucks.
    I would suggest not to buy thsi product, you will be disappointed. Also i should mention that i had no riough use in the car, im the only one who drives the car and my GF dreads tech stuff and stays away from touching anything without asking me. She sat a few times as a passanger and she does not drive my car.
    They need to have strong joints that can withstand leverage type forces.
    Finally, the screw behind the LCD that tightens to grip the LCD, no matter how much you tighten it, it will never be tight enough to stablize the LCD. It wont move on its own, but a little nudge of your hand by mistake and it will rotate the display about 20 degrees.
    Currently i have tied the top of the goose neck to my hand brake lever with a plastic tie, and thats how its pretty stable now but i know its not the way i should do it. Unless i find another non invasive solution, to install a LCD in my car or somone has a better goose neck, i will have to cope with this crap.
    Any other solutions someone knows of out there?? better gooseneck?
    Chrysler Sebring 2004 Conv Limited Ed.
    Commell LV-677.
    Voom PC case.
    M2 ATX PS.
    1.8Ghz Intel Core Duo.
    1GB PNY RAM.
    Dynamix 816 (8", Wide, TS).
    80GB out of a broken laptop.
    WiFi Atheros (HP) out of a broken laptop.
    OS: Win XP MCE.
    Mar 2006
    Colorado, but Canadian!
    Well goosenecks are the wimpy way out. They are meant to be flexable.
    If you want something better, mold it in your dash, or get a motorized one.
    You will never be truly satisified with a gooseneck.
    1.9in x 2.9in -- 47mm x 73mm
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    This really should be in the review section, if at all on the forum.
    Check out www.Ram-Mount.com Website is not the greatest for navigation, but the product works really well, and you will find what you need there.
    Are you sure you are not Maheriano. You seem to behave like him, and he has been suspiciously absent lately. Is that you?
    Michael
    Jul 2004
    Irvine, Cal
    Quote Originally Posted by 2k1Toaster View Post
    Well I have had the same goosneck and it hasn't been a problem with me, everything work great....for now atleast.
    Also for those saying it's the wimpy way out, well no it's not. It's a matter of preference, actually, as my car has a double din and a molded screen could fit in pefectly. I chose not to do that and got myself a mount...why? because it can easily be faced to whomever wants to see the screen (pefect for me to see the gps directions, perfect for my passenger to see movies, etc.) and if i chose the molded option, it would be located smack down in the middle of the console and be inconvenient for me and a hassle for my passenger.
    Mar 2006
    Quote Originally Posted by HitmanZ View Post
    I just think it looks ghetto when there is a metal swing arm coming from the floor. Unless you have an 18 wheeler that shouldn't be there. The only way that I could see it would be an inconvenience would be if you had a gargantuan truck of doom, and the center console is so very far away. I don't know what you drive, but I'll take your word for it.
    On the subject of vehicles, where the heck did our vehicle bar go by the avatars!? hmmm.
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    We are losing a little bit everyday......next our avatars will disappear and
    all the post will come out as 010101010101
    "A rose by any other name is still a flower"
    Mar 2006
    Quote Originally Posted by Pathos View Post
    01001001 00100000 01101100 01101001 01101011 01100101 00100000 1110100 1101111 00100000 01110010 01100101 01100001 01100100 00100000 01100010 01101001 01101110 01100001 01110010 01111001 00100001
    ASCII encoding of course
    Jul 2004
    Irvine, Cal
    Not that ghetto, but def not OEM...This is sean's install which kinda looks like mine
    Mar 2006
    I don't like seeing wires. I see wires.
    Whatever works for you though. Mine is not yet OEM looking either, but all I have to do is put the trim kit to fit the weird opening. Now there is a little (< 2mm) gap on the right side.
    Mar 2006
    I can feel it coming...
  1. LCD gooseneck mount
    By capnal in forum LCD/Display
    Last Post: 10-11-2006, 12:20 PM
  2. Need help with fiberglass LCD mount PT Cruiser
    By mag2 in forum Fabrication
    Last Post: 07-14-2005, 01:16 AM
  3. mount LCD w/o housing - lilliput 619
    By cybermob2 in forum LCD/Display
    Last Post: 05-04-2004, 04:14 PM
  4. Replies: 12
    Last Post: 03-31-2004, 02:37 AM
