Results 1 to 10 of 18
Thread: yeaaawww: My controller arrived, ARRRGGHH: a few problems
    Mar 2002
    Portugal - Cacém
    My controller arrived today and it is working great.
    Now for the problems:
    My LCD is an 18bit one (sharp LQ104V1DG11), and in the properties in my PC i can choose between 16bit or 32bit only, now, when i choose 16 bit everithing works great, but when i choose 32 bits the screen "flickers" a bit (expected reaction), so i've been using it in 16bit mode, but i want to take full advantage of the screen, is there any software or "mod" (maybe in the registry??) that i can use to make the graphic card output 18bit? 16bits is fine, DivX and DVD looks great, but if can make it even better, that's fine by me
    Thanks for the help.
    Shades
    Variable Bitrate Rireal's Avatar
    Jun 2002
    Jacksonville, FL
    I'm sorry I don't have an answer to your question, but what size is your LCD and how much was it including the controller?
    Tres
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    things to check...
    is the resolution your video card is running within the capabilites of your lcd? (i.e. trying to run 800x600 on a screen that can only handle up to 640x480)
    is the refresh rate within lcd spec? some will only work at 60Hz, some can handle 75Hz.
    check out powerstrip... you can run custom resolutions, probably custom color settings as well...
    check the controller datasheet or manual... there may be a limit on the controller's capacity...
    what controller card do you have??
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
    Mar 2002
    Portugal - Cacém
    Rireal:
    Everithing, and i mean material, shipping, burocracy, etc., costed me 380€ aprox.
    mp3z24:
    Everything is checked, every value was tested, please understand that i don't have a problem with the screen nor the controller, what i want is to change a value in the Windows monitor properties, the color depht that my Windows let's me choose is:
    16 colors
    256 colors
    16 bit
    32 bit
    What i want there is to add the 18bit option, or if not possible, lock it in the 18 bit option, either is good since i'm not going to change it anymore.
    I'll go and test that software that you mentioned, i'll post later the results.
    Thanks for all the help
    Shades
    Jun 2002
    Jacksonville, FL
    thanks, but what size is the LCD? And where did you get it if you don't mind me asking
    Tres
    Sep 2001
    Hey what inverter did you get for this screen? Doesn't it take two of them?
    Mar 2002
    Portugal - Cacém
    It's 10.4", got it from eBay, the controller bought from TSOUBIS
    Shades
    Mar 2002
    Portugal - Cacém
    The inverte r i have is ISI1502, but i know that you can use also CXA-0217 from TDK
    Shades
    Sep 2001
    Did you use 2 inverters?
    Mar 2002
    Portugal - Cacém
    No, the same controller supports two lamps, it has one input an then has two circuits, one for each lamp, but everithing is on the same PCB.
    See this pic of the CXA-0217, mine is almost the same thing
    Shades
