Page 12 of 16 FirstFirst ... 2345678910111213141516 LastLast
Results 111 to 120 of 159
Thread: New Xenarc MDT-X7000 for CES 2007
  1. #111
    Jul 2006
    Baltimore
    Reapur,
    I have answered your questions on the below post.
    http://www.mp3car.com/vbulletin/mp3c...er-bundle.html
  2. #112
    May 2003
    how about handling backup camera? Can it be connected easily and switch to the backup camera automatically when the car backs up?
  3. #113
    May 2007
    Does the display open at less than 90 degrees?
    My DIN opening is at ~45 degrees and not vertical with the dashboard. Because the 700IDT was spring loaded, I could use it as there nothing making it open to a full 90 degrees. With this new display being motorized, is it possible for it to open at less than 90 degrees? The video shown does not appear to allow for this...
    Thanks,
    Dave
  4. #114
    Aug 2005
    good question
  5. #115
    Apr 2005
    Queens, New York
    OK does any1 know if the xenarc has a GUI interface while in radio mode (headunit mode)? Or does it look like the other xenarc menu screens when you change the brightness, mode and other options like that.
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  6. #116
    Jul 2006
    Baltimore
    [H]Bugster - The back up camera connects and switches over very easily. With out software control.
    dharris2112 - The screen will open to the last position it was in before shutdown. As far as the angel I am unsure of the minimum degree you can set this to. If I get 10 seconds to test this I will get back to you. If anyone who has this in there car can report that would be great!
    Cheekz185 - The GUI for the radio is similar to the one for the other options in the video. its not a pretty as SD but it still works fine.
  7. #117
    May 2003
    Quote Originally Posted by StreetDeckAce View Post
    Thanks. Do you know if there is plans for a double-din version LCD? I would like to see more competition for the dww-6500 (which im leaning towards)
  8. #118
    Variable Bitrate john05srt4's Avatar
    Oct 2006
    Florida
    Quote Originally Posted by [H]Bugster View Post
    exactly what he said.. we want a double DIN version please.. ill buy 2 of them..
    10 acura TL tech
    10 BMW S1000RR
  9. #119
    Jan 2007
    I read somewhere that you could use the radio, but still display in pc mode, just not be able to listen to anything coming from the pc. That when the radio is turned on it just activates the radios function and cuts off any audio from the pc. Is this true? Or when you go to use the radio, are you stuck in the radio gui screen.
  10. #120
    Low Bitrate sounder's Avatar
    Aug 2001
    Atlanta
    Quote Originally Posted by elimenohpee View Post
    I would like to know the answer to this question...
    Subject open, Subject closed.
  1. Pandora w/ Xenarc 700TSV and Barrel Connector
    By froalskiner in forum General Hardware Discussion
    Last Post: 07-20-2006, 03:39 AM
  2. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  3. Xenarc issue with ATI AIW 9600Pro
    By lookinco in forum LCD/Display
    Last Post: 09-23-2004, 10:47 PM
  4. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  5. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
