Page 14 of 16 FirstFirst ... 45678910111213141516 LastLast
Results 131 to 140 of 159
Thread: New Xenarc MDT-X7000 for CES 2007
  1. #131
    Nov 2007
    Sydney, Oz
    I believe I have solved the problem with the MDT-X7000 screen closing down.
    It is due to insufficient current, or voltage.
    Try running it from a very good power source, eg. the battery. Connect both the (Power and ACC wires) to "+" together, and the (Earth and Handbrake) to "-" together, for the test.
    If you are running it off the bench, ensure you have at least a 4Amp power supply.
  2. #132
    Nov 2007
    Quote Originally Posted by allypally View Post
    I thought so too, as I started with a little RatShack unit. the unit flickered and acted like it was low on power and would not open. so I bought a unit capable of up to 10a. once I hooked this one up it would open and then hang at the "enter id" screen. no amount of fiddling would get it to close. I also inserted a CD and it refused to eject that But now I have a very nice bench power supply!!
  3. #133
    Nov 2007
    Engine33r, is your response about the x7000?
    would the transflective be a better screen?
    how would one handle front/rear fading on the transflective does it have outputs that will split the output from the PC into front/rear?
    thanks
    Rob
    Hey, I am also in America
  4. #134
    Jul 2006
    Baltimore
    Have you tested a transflective LCD from the Mp3Car Store?
  5. #135
    Jun 2007
    Does the standalone unit play MP3s?
    As the title sais, can the MDT-X7000 decode MP3's (for example burned on a DVD or CD) while in standalone mode? ie. not connected to a PC. Or does it only play Movie DVD's and music CDs?
    Searched for a few days on this but couldn't come up with a definite answer.
  6. #136
    Jun 2007
    bump for an answer..
    Thanks!
  7. #137
    Jul 2006
    Baltimore
    From the documentation that Xenarc has on the unit it does not have this feature. We are currently out of stock and can't test this.
  8. #138
    Jan 2008
    does this monster have preamp outs? This is definitely a huge step in the right direction. I wish they made it a double din, though.
  9. #139
    Jul 2006
    Baltimore
    The MDT-X7000 does have preamp outputs for full range and sub.
  10. #140
    Jan 2007
    Grand Island, NY
    MDT-X7000 Comments
    My lilliput 701 gears stripped so it no longer ejected the monitor. The week this happened, MP3Car announced the X7000. I saw that is was similar to the 701 and put in an order. I was impressed that the AMP and monitor were better quality, but just a little. I like the built in drive, but I was expecting that the disk drive would be available in PC mode as a DVD-ROM. In the PC mode, it is a CD-ROM drive only.
    I don't have high expectations of this installation. I have this installed in my daily driver, a '07 Corolla with the PC in the trunk, SD auto and NAV. I have been waiting for FM and Bluetooth phone support from MP3Car and some reviews, so I thought a built-in FM in the head unit would allow me to bide my time.
    The head unit is power hungrey and I have to run better than factory wiring to it. When the break lights go, or the A/C kicks in, any accessory, the radio fades for a second or less.
    Also, one frustration I have is that if I don't turn on the head unit and set it to PC Mode BEFORE the PC boots, I cannot view the PC video. I don't have the unit PC power wired to the trunk yet, so the PC powers on with the car.
    I love all of the inputs and outputs of the unit. I do not like the default safety of the unit. You must disable the video safety of the unit to be able to view PC screen while driving. I would like it to only disable DVD movies.
    Hope this helps.
    Doug
  1. Pandora w/ Xenarc 700TSV and Barrel Connector
    By froalskiner in forum General Hardware Discussion
    Last Post: 07-20-2006, 03:39 AM
  2. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  3. Xenarc issue with ATI AIW 9600Pro
    By lookinco in forum LCD/Display
    Last Post: 09-23-2004, 10:47 PM
  4. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  5. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
