Results 1 to 5 of 5
Thread: what would drawbacks be to this monitor
    Dec 2006
    http://cgi.ebay.com/14-inch-OVERHEAD...QQcmdZViewItem
    My plan would be to disassemble the housing and fiberglass this monitor into the dash, it has a remote to control power etc. should be ready to run on 12v, what kind of inputs do these usually have? and would the resolution be acceptable for a main monitor in a car pc?
    Or this one I didn't want to go touchscreen but it looks like a complete kit and the price quite low
    http://cgi.ebay.com/NEC-12-LCD-Displ...QQcmdZViewItem
    Elsewhere
    Resolution appears to be fine, but there's no VGA input. That will reduce teh quality of your display significantly. It would also require you to have hardware that allowsd you to output video signal to a composite video port.
    The second link would require additional parts to get operational with a VGA signal, and would make the low cost of teh bare screen not worth it in my opinion.
    How about the Wiki?
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    Quote Originally Posted by DarquePervert View Post
    huh? come again??
    a 70.00 lcd controller and you have a 12.1" ELO/NEC s.a.w. setup. Not worth it???
    Ok, maybe I missed the boat, but where else are you going to build or buy that quality for less than 200.00???
    Have you seen the specs on that lcd panel?
    btw, that seller is a great guy. I have been buying from him for 6+ years. Always has top shelf stuff cheap.
    Elsewhere
    I would have thought that the controller would be a lot more than that.
    I stand corrected. That's a damn fine deal, then.
    Add a touchscreen overlay, if needed and that's some right fine screenage.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    If these are going to be used to show the XP desktop and used for the computer...I'd look elsewhere.
    If it's going to be used solely for video playback, it should be fine.
    Jan Bennett
  1. Help needed RGBS monitor - needs VGA input
    By Zductive in forum LCD/Display
    Last Post: 10-13-2007, 05:50 PM
  2. Headrest Monitor or Dash Monitor
    By BIzFlawless in forum Classified Archive
    Last Post: 01-28-2006, 04:16 AM
  3. Replies: 1
    Last Post: 04-10-2005, 06:24 PM
  4. Replies: 1
    Last Post: 03-23-2005, 12:41 PM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
